REVpuggie
box impedance rise
Hey all ,
I've got this AA mayhem 15 inch dual 2 ohms wired to 1 ohm , now BBpro6 tells me that the minimum impedance under load will be 2,05 ohms in the box its playing in , is this what the amp will see or will the amp still see the Re of 0,7 ?
thanks in advance .
The RE is at DC, which you shouldn't see under normal use.
A bit of reading material :
thanks for the reply , I was looking for that but couldnt find it
My amp goes into protect on hard notes with bass kranked as soon as i get close to the 150's the amp goes into protect....?????? dont know if its heat droping my load to low or what but its getting frustrating. im wired to 1.7 amp fosgate 1ohm stable.
thats probably because of a high voltage drop , check your batteries, wiring and alt
Could be over excursion as well, too little coil in the gap = low impedance.
