FiBl15
ixl 10 parameters
anyone have the parameters layin around for the ixl 10? Mach 5 took the ixl 10 off there sight and now i cant find the specs. any help is appreciated
Which version?
I have the specs for the 2.2 version:
Parameters
* Power handling: 1000 watts RMS
* Sensitivity: 84db (2.83 volts) - coils wired in series (4 Ohm nominal impedance)
* Impedance: 2 + 2 Ohm (DVC)
Dimensions
* Outside Diameter: 26.4cm (10 3/8")
* Mounting diameter: 23.2cm (9 1/8")
* Depth: 14cm (5 1/2")
T/S Parameters
* Fs: 27.8 hz
* Re: 3.7 ohms
* Qes: 0.46
* Qms: 6.44
* Qts: 0.43
* Mms: 234.1 grams
* Rms: 6.34 kg/s
* Cms: 0.14 mm/N
* Vas: 13.9 litres
* Sd: 265.9 cm2
* Xmax: 20 mm (one way linear)
* Cone Diameter: cm
Recommended Box Sizes
* Sealed: car installations - 17 litres (0.6 cu. ft.); home installations - 19.8 litres (0.7 cu. ft.)
* Ported: car installations - 22.7 litres (0.8 cu. ft.) 36hz tuning; home installations - 28.3 litres (1 cu. ft.) 32hz tuning
Which version?
Parameters
Dimensions
T/S Parameters
* Fs: 27.8 hz
* Re: 3.7 ohms
* Qes: 0.46
* Qms: 6.44
* Qts: 0.43
* Mms: 234.1 grams
* Rms: 6.34 kg/s
* Cms: 0.14 mm/N
* Vas: 13.9 litres
* Sd: 265.9 cm2
* Cone Diameter: cm
