ls1pimp
Can you guys critique my projected box specs?
2.03 cubic feet BEFORE sub displacement, tuned to 34 hz, 30 inches of port area. Is that gonna be sufficient to get me the output i want, as well as still retain a good amount of SQ?
The driver displaces just under 0.2 cu ft FYI. In my opinion, a 1.85 cu ft net vented enclosure tuned to 34 Hz would be a great enclosure for the RL-p12. Whether or not it will be sufficient for you, only time will tell... a slightly higher tuning will afford you more overall output, at the expense of low-frequency extension.
the projected box u have lined up will work fine. especially since u like the low lows...
the box mike suggested would be sweet too..tighten up the response a bit..
hopefully,u'll get the output ur after...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
can he have the bigger box made and if hes not happy add some mdf to make it smaller internally?
yeah...but when u slug a ported box to take away volume, u raise tuning....
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
Sounds like a good plan... but where are the real numbers/design? I won't sign off on a plan until I know ALL of the variables.
Like dimensions, port length, etc.
Look at flakko's thread for a good idea what you need...
Until then, I assume you have a box with a hole in it.
