Acidburn 10 Posted March 30, 2007 updatesresin on the fleece:first time i used my circle jib, damn that's slick, i have to make 3 more of these:top of the box with the tabs that will hold the bolts that'll hold the box to the rear deck: 0 Share this post Link to post Share on other sites
Adrian_D 520 Posted March 30, 2007 nice work mang ! 0 Share this post Link to post Share on other sites
///M5 2,833 Posted March 30, 2007 No more T-nuts. 0 Share this post Link to post Share on other sites
Aaron Clinton 2,372 Posted March 30, 2007 Very ncie work Tom! 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 4, 2007 updates2 glued rings and 2 waiting to be glued rings:they now have 3 layers of FG cloth on them:anyone want a sawdust cake? 0 Share this post Link to post Share on other sites
Godsmack 360 Posted April 4, 2007 If it has resin icing sure!!!!I like the build so far tom.Teach Wade alot PLEASE.J 0 Share this post Link to post Share on other sites
Bigpete123 1 Posted April 4, 2007 Sweet. So I take you plan on using FG for the front of the woofer as well? I assume so since you're making speaker rings like that. 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 5, 2007 Sweet. So I take you plan on using FG for the front of the woofer as well? I assume so since you're making speaker rings like that.kind of, but not quitethe FG will be used to make a cover panel for my rear deck which will cover those rings 0 Share this post Link to post Share on other sites
ngsm13 1 Posted April 5, 2007 Hurry it up slowy McSlowerson.ng 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 9, 2007 updatesall of the visible screw holes bondo-ed up:all interior seams sealed with resin:rings and subs ready to go:stuff to do before the SD meet:sand outside of the boxesspray boxes with truckbed linercut holes in rear deck largermount boxes to rear deckadd polyfilinstall subs and wire 'em upreplace tweets 0 Share this post Link to post Share on other sites
Aaron Clinton 2,372 Posted April 10, 2007 Looking great tom! 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 12, 2007 updatessomeone stole my backseat!:one of the holes in the rear deck, not pretty but it'll work:new tweeters:smaller than I thought they'd be:stuff to do before the SD meet:spray boxes with truckbed linermount boxes to rear deckadd polyfilinstall subs and wire 'em upreplace tweets 0 Share this post Link to post Share on other sites
Bigpete123 1 Posted April 12, 2007 nice, dude.I cut the same sort of hole in my rear deck. It's very tough to make them pretty- it's not like putting a circle jig on a router.Looking forward to more progress pics. 0 Share this post Link to post Share on other sites
ANeonRider 3 Posted April 12, 2007 Where did you get those tweeters from? 0 Share this post Link to post Share on other sites
///M5 2,833 Posted April 12, 2007 Pacparts. XT19 knockoff cheap, same way they had the D2904's a while back. Bang for the buck, I really dig mine and they should work out stellar in Tom's car. 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 13, 2007 last updates before the SD meettest fitting the boxes:boxes complete:being sprayed with truck bed liner:wires: 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 23, 2007 the sub boxes are completepeaking through the rear deck:with the factory padding in place:from the trunk:and the new tweeters installed: 0 Share this post Link to post Share on other sites
///M5 2,833 Posted April 23, 2007 I love the subs peeking through, if my M weren't what it is I'd probably go that route albeit perhaps without the enclosure.*clears throat*YELLS: "Deaden your doors" 0 Share this post Link to post Share on other sites
Acidburn 10 Posted April 23, 2007 they are deadened... i've got about 25 sq feet in each...well, it might be closer to 20 each now that a lot of the eDead has fallen off 0 Share this post Link to post Share on other sites
Aaron Clinton 2,372 Posted April 23, 2007 Looks great tom, you do good work. 0 Share this post Link to post Share on other sites
