lolitskasey
Speaker wires
8-10 gauge.
Say you use 8 awg, How would you fit 2 8 awg into a terminal since you have to bridge them. Ex) 4 ohm dvc wiring at 2 ohm. Whats the most common way to fit the wire? Solder it together?
If it does not fit you may trim it with a cutter. Please dont solder your wire....just stick it in there
Into a terminal in the sub? You don't have to do two.....
Into the amp outputs? I used 4 gauge for my speaker wire and I used distribution blocks.
fray them and the solder them together like fray them and cut it down a little bit then solder them together
Male banana connectors.
Well fraying them down would defeat the purpose wouldn't it? Some of you didn't understand what I meant though. For example.. Where I circled is where two wires need to be fitted. 1_4ohm_dvc_2ohm.gif
Well what do you know lol, male banana plugs! They will work, its for a 15" the terminals are quite far from the sub od.
Well my sub is a 12, and I tried it and it didn't work. But for his 15" bl it will work. All I am asking is, What is the regular way for fitting these wires.. The trick of the trade... Just use smaller wire? lol
The way I have always done it is banana plugs.
Does partsexpress carry the ones you use? Cause the ones I got were too long.
I use cheap banana plugs that you crimp.
What's the largest two wires you are able to fit in there?
Two 8 gauge strands lol
