rcmobile
soundstream xxx-6500
would two 18 fully loaded BL's take the soundstream xxx-6500 amp? they are ported of course tuned to 35hz with two hifionics clossus one on each, they wang hard as hell. but just wondering if this amp would be too much?
it is 4800 at 2 ohms
and 6400 at 1 ohm
but i have been told they were much stronger than rated but with voltage drop i should be around that range>>> should wang i think
i think they will take that just fine i think steave meade has like 5000 a piece on 4 btls
I say 4 bl 18s off the xxx6500. Why,................why not :fing34::excl:
from what i hear those are ratings are at 16volts.....
its more like 4000@1ohm and 28-2900@2ohms i've been hearing
so i think the BLs can handle that for sure
my bad ...
Soundstream XXX-6500D
Output Power at 1% THD+N:
1 x 1697W @ 4 ohm (13.5V)
1 x 1750W @ 4 ohm (14.4V)
1 x 2905W @ 2 ohm (13.5V)
1 x 3290W @ 2 ohm (14.4V)
1 x 4082W @ 1 ohm (13.5V)
1 x 4490W @ 1 ohm (14.4V)
The page lists (RMS, unknown voltage and THD): 3400W @ 4 ohm, 4800W @ 2 ohm, 6500W @ 1 ohm
S/N Ratio: >80 dB
Damping Factor: >350 @ 80Hz (+/-5Hz)
Operating Freq. (band-width): 15Hz ~ 150Hz
Dimensions: 24.53" x 11.42" x 2.56" (62.3cm x 29cm x 6.5cm)
Max. DC current: 465A DC (1 ohm, 1% THD+N)
Same board as:
. Audiobahn A4KDN
. Ground Zero GZPA 1.6000D
. Lanzar OPTI 4000D
thats from amp guts.. personally i think the amp is a waste of money and current unless you have 16v electrical.. i would look into something different
well i may build a 16volt bank for it, and it is being hooked up from a friend that owns a shop so no money involved :woot:
That power for daily? If so, its a wee bit much if on a 16V setup. I dont recommend more than 2000W to them for daily (your mileage may vary and Im sure others will pop in with their stories of using more than that...)
