Kicker Guy
SSD 12 problem
Hey guys, as the topic says I have a problem with a SSD 12... the spider feels very weak in a spot like there is a crack under the top one.
So my question is will it be fine to run like that? (i don't know how long its been that way but it worked fine till the day I took it out) or do I need a recone so it doesn't get any worse?
Thanks
They are going to get soft after running them for a while...
If it becomes an issue then it should be covered under warranty
Post a picture if you get a chance.
Thanks
-Nick
Does the speaker bottom out or the like? Usually they say beat on it [ music ] till it becomes a problem if it becomes a problem,.....they will help you if it does
