The General 22
Fi SSD box
I have 2 12" Fi SSD's with copper coils coming soon and I need a box for my Charger and found this.
http://cgi.ebay.com/2006-Dodge-CHARGER-SUB...%3A1%7C294%3A50
Would this box be ok to use or should I have a shop make one?
I also found a ported one
http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=21319
I mostly listen to rap but also listen to rock, death metal, etc. if that helps
Edited by The General 22
That box looks ok, but if you can afford it, it would be well worth having one of the custom builders on this site build you one specific to your install.
Would something like this work? I cheated by the way.
3/4 MDF 4.5 cu ft 32.8 hz before displacement
Width 34
height 18.5
depth 17
sq port height 17
sq port width 2.5
sq port length 13.75
sq port area 42.5
sq port diameter 7.35
total port length 18.25
i like to keep it simple so all cuts are 17"
top - 34
bottom - 34
left - 16.25
right - 15.5
front - 30.75
back - 34
port L1 - 13
Im thinking both subs in the same arispace. Some bracing couldn't hurt in the middle section.
Width 34
height 18.5
depth 17
sq port height 17
sq port width 2.5
sq port area 42.5
top - 34
bottom - 34
left - 16.25
right - 15.5
front - 30.75
back - 34
port L1 - 13
I think 34" is about a half inch too wide for my trunk
Width 34
height 18.5
depth 17
sq port height 17
sq port width 2.5
sq port area 42.5
top - 34
bottom - 34
left - 16.25
right - 15.5
front - 30.75
back - 34
port L1 - 13
That 1/2" in width isn't going to impact the volume that much. It'll be like .07Ft3 of less space.
Width 34
height 18.5
depth 17
sq port height 17
sq port width 2.5
sq port area 42.5
top - 34
bottom - 34
left - 16.25
right - 15.5
front - 30.75
back - 34
port L1 - 13
I meant my trunk is only 33 1/2 inches wide.
