jjg052590
bad idea?
I was thinking of taking the subwoofer out of my room and putting it in my truck(temporarily) until I buy my stuff I want. It has an RCA' and positve and negative wire. I was thinking connect the power to my remote wire, the negative to the ground and RCA to RCA. Is this a really bad idea? or what? Thanks guys
you will get no power out of your remote wire ... it is just a 12 volt constant to turn on your amp with little amperage
So how could I wire it up??
Run a separate power wire from the battery. But you'll have to make sure that the sub amp will accept 12 volts since it apparently belongs in the home on 120v. But since you don't have a remote wire it may be on all the time, except if it has an auto-sensing feature from the RCAs. If it doesn't have that feature, it will stay on all the time and drain your battery.
Basically, bad idea. Wait til I can afford my real setup
yeah thats what I would do so I want cause my car any problems in the long run.
good idea. I just think it may be too many headaches.
Good advice by everyone, don't bother.
JP
