Jbabycsx
Audioque sub question
I just got two Audioque HD 12's and I need to know if they will perform well using the SSA XCON dual 12 box design. They will be powered by a 3000d in a 90 Mustang. I sent the box designs to a builder but he is not familier with Audioque. What do you guys think? Need feedback ASAP!!
No! AQ uses the DD philosophy of tuning in the 38-40hz range and they will suffer in the lower tuned box alignment!
So I should make the port wider and shorter in length to raise the tune to around that level right?
Just shorten it is all I would do. Just remember that those boxes were designed around the SSA XCON drivers.
