mathewdylang
port tuning differences
I know port tuning makes a difference. And I know what the differences are, but would there be an audible/easily noticeble difference between 30hz and 34hz tuning? For the larger amount of port area I want for my smaller box, I would have to tune around 34hz, instead of the 30hz I wanted to tune at.
Tuning the enclosure is only an "open room" tune. It will be completely different once inside your vehicle.
Depending on the application a 34hz tuning will be just fine for daily and could get low as well. But again that is dependent on the the application and products used.
It would be a 98 bravada (s10 blazer), 15" AA Havoc, and a MB Quart Discus 1.5k
4 door? If so you should have enough room to go a little large on the enclosure and tune lower which is what I would suggest in your situation. The acoustical gain/loss you get in the truck is very different in the blazer then almost any other SUV.
so playing around with my box tuning calculator and this is what I got? any inputs?
Gross Volume = 6.26ft^3
Port Volume = 1.75ft^3
Physical Port Length = 33.25in
Port Bends = YES
Baffle Displacement = .3ft^3
Port Area = 63in^2
Port Area per Foot = 15.94in^2
Net Volume = 3.95ft^3
Tuning Frequency = 30.37hz
