March 20, 20179 yr Author I seen right after it happen cause i heard it and ran to the window and seen the person speed off . . Didnt get the plate but Iv seen the car in my neighborhood befor so im hoping I see it again
August 17, 20179 yr Author Should be getting started on the wall within the next few days . Just got a bunch of 4/0 im about to run to. . Mite be 3 18s if they will fit and amp will probably be an ampere 9k . Ima still try the taramps 10k but thinking the 9k will be better if it can fit it somewhere. The thing is huge
August 21, 20179 yr Author Been collecting dust for a while. That 12 sitting there mite be the other 18 in the wall
August 21, 20179 yr Author Most of the Last enclosure is still in there . Probably going to leave most of it since its bolted in and I can use it for a floor for batts and amps
August 21, 20179 yr Author Going to pl some layers of wood to the top . Its already solid as shit with just that one piece
August 29, 20179 yr Author Only way to do the 3 18s in here is to do a round port . . Im hopin an 18-20 in port will be enough for the 3
August 29, 20179 yr 3 hours ago, frogcase2002 said: Only way to do the 3 18s in here is to do a round port . . Im hopin an 18-20 in port will be enough for the 3 That's a huge port!! Gotta see that
August 29, 20179 yr Author 4 hours ago, ManzKea said: Thait's a huge port!! Gotta see that I know lol . Going to be crazy to make . Would rather just do a slot port but The way Im doin the wall I am only going to have a little over A 40in square To work with on the face of the wall
August 29, 20179 yr Awesome. Im curious on how much of a difference the roof will make. I have yet to do anything with mine. But it's on the list. Good luck and get loud.
September 11, 20179 yr Author Slow process but ill get it done lol . Just workin on it the little bit of extra time I got at the shop
September 11, 20179 yr Stick with 2 go optimal. Have fun with it man. Dont shove it in there. Plan and execute. Looks good so far.
September 11, 20178 yr Author 5 hours ago, Travis said: What thickness you usin on the roof? About to start mine. Time willing. 3 layers of 3/4 " . Its going to be the top of the enclosure/wall though . . . . Just one layer made the roof solid as shit
