ABXX49
box
Just wondering if someone could give me some plans for a ported box. Nick told me to post here and someone would be able to help me....
sub - Fi Q12
amp - TXA 1000-D
max dimensions:
-Height - 16"
-Depth - 18"
-Width - 36"
Thanks,
Ryan
It's just going to be a daily driver. I'm going for some powerful bass, but I don't want to entirely throw SQ out of the door....and I'm not sure I know what T/s means....I'm a noob >.<
I can throw one togther for you. you have more than enough airspace. . . .do you want me to cut length, width, height, or a combination of all three from you max dimension?
I did this box in another thread that would work for you:
It is tuned around 32 Hz. If you want to tune lower, the port could be extended and a little width added to keep the same net airspace.
You have enough airspace for a pair of Q's :D
Let me know.
Brian
Yeah, like I said, I'm relatively new to box building and stuff...If that's what you recommend I'll do that. :)
I should use 3/4" MDF correct? And how much does it cost, roughly?
And were exactly, if using that design, should i mouth the sub? Far left?
That box will work. Mount the sub in the center of the doubled piece between the port opening and opposite wall.
Since you have room, you could make that box 1" taller. . . .everything else the same. Would give you 2.5 ft^3 tuned to 31-32 Hz.
Alright, thanks alot man....I really appreciate all the help!
Starting the build tomorrow :)
