wof131s
Box for a 15" DP help
Am trying to find out if a box that is 3.75 cu.ft net vol. with 64.5 sq.in of port be to small for this sub. I was considering buying a DP over a DR and needed to know. If it is them ill go with a DR in the same box. Am looking for mostly authoritive low-end bass, the box will be tuned to 30~32 Hz. How does this sound for what am looking for? Any input will be helpful.
Thanks
Edited by wof131s
Did you give this a look at?
http://www.soundsolu...ing-t28822.html
I dont see why that box wont work for either one, what amp will be on this sub?
Yes i did. I was just wanting to know if i would be able to get the low end extension with a slightly smaller enclosure than the average size enclosure that i saw on the IA site. Im using the AQ 2200D amp, but will set the gains so that it put out around 1800 watts. How does this sound?
with that much port, it'll have to be a pretty large enclosure.
what type of power are you running?
I am using an AQ 2200 amp. With that size box what size enclosure would you recommend? I could probably do a 4 cu.ft but the port would be like 2~3 inches from the side wall of the truck. I was thinking that this would take away from the sound and cause port noise.
Edited by wof131s
