I need to know how many cubic feet for two 21'' warden? these will be driven by two memphis mojo 4k and is for everyday use and demos ,and how many square inch in the port for both tuned at 34hz ,the box put in my Ford Expedition 2000 thanks
Search!! have you looked at the website? :suicide-santa:
These are the recommended enclosure specs for the 21" death penalty and they will also work for the Wardens. If you use the average of 8.5 cubes and 120 sq in of port(12x10 port), then the port would need to be around 24 inches long. Keep in mind this is for one woofer so work it out for 2 woofers for your setup. Let me know if you need anymore help.
21" DVC1, DVC2 & DVC4 ohm
Sealed Not Recommended
Ported 7.5 cubes - 10.0 cubes, 90 - 160 Inches of Port, 32-37 Hz
Average: 8.5 cubes, 120 inches, 32-37 Hz
yes, but it's also good to have information of people who are using and more with the type of power that will put them
in my neon i have them with 236 sqin of port, tuned to 31
the enclosure is 15.9 cubes, and on 2 amps (3600w) it will do a 153.1 and blow hair everywhere all day long.
hope that helps.
