Nikuk
Jaaaaaaaaaaaymac
The math looks good to me, but can You superenginebuilderextraordinaire's check it for errors in theory.
To figure VE of an engine in a given application, You'll need to run a test of airflow. To keep it simple, run the engine @ 7k rpm while measuring the amount air drawn into the intake manifold (lb/min or cfm), and the temperature of the air (IAT).
Now, bear with me:
Density: t1 / t2 = d2 / d1
  • t1 = temp for air of know density (32* F @ 0.0808 lb/ft^3) in Rankin
  • t2 = IAT (in degrees of Absolute Rankin, F* + 459.67)
  • d1 = density of air for known temperature (0.0808 lb/ft^3 @ 32* F)
  • d2 = Density of intake air charge
AVF = Actual Vol. Flow Rate (calculated): Mfa/d2
  • Mfa = Mass air flow actual (measured)
  • d2 = air density actual (measured)
Calculating Theoretical Max Airflow (cfm): TAF = (ED*RPM*VE) / (ES*C)
  • rpm = Operating engine speed
  • TAF = theoretical airflow
  • VE = Vol. Efficiency (100% theoretical )
  • ED = Engine Displacement (in^3)
  • ES = Engine Stroke (2-stroke = 1 / 4-stroke = 2)
  • C = conversion factor from in^3 to ft^3 (1728)
Calculating Volumetric Efficiency: (AVF/TAF)*100
  • VE = Vol. Efficiency (calculated)
  • AVF = Actual Vol. Flow Rate (calculated) (ft^3/min)
  • TAF = Theoretical Airflow rate (calculated) (ft^3/min)
So, we have our equip tested. We come up with: 17.14 lb/min --OR-- 243.8 cfm @ 7000 RPM with our 122 (in^3) engine. The IAT was reading 72* F.
Now, do the math:
  • Density: t1 = (32+459.67) = 491.67; t2 = (IAT+459.67) = 531.67; d1 = 0.0808. So: 491.67/531.67*.0808 = 0.0747.
  • AVF: 17.14/.0747 = 229.43.
  • TAF: rpm = 7000; Displacement = 122. So: (122*7000*1)/(2*1728) = 247.11
So, 229.43/247.11 = 0.9284 or 93% VE @ 7000rpm.
That about right?
Thanks,
-Nick
lol, I meant does the theorum look right to You? Given density et al. :)
Nick
Oh, okay, I just did the math :P
Calculating air density is more complex than that ...
Here's the shortcut form that is mostly correct (but incorrect between -1 and 1 degree celcius) ... Only reason I use this is because the actual equation is really, really long ...
AIR = ((BAR*1000/(287.05*(TEMP+273.15)))+(100*(6.1078*10^((7.5*TEMP)/(237.3+TEMP)))*HUM/100/((461.495*TEMP))))
AIR = Air density in kg/m^3
BAR = Barometric Pressure in kPa
TEMP = Ambient temperature in *C
HUM = Relative Humidity in %
cool, I knew You had it somewhere.
that works out in my Excel.. nice. Overall it looks good. Thanks.
Now, off to the flowbench.
