Hzd Skizzy
Comparison?
Im wondering which to get. 2 Fi SSD 12s in its optimal enclosure or 2 Sundown Sa-12s in their optimal enclosure both will be running on the same amp. Im wondering which would get loud and retain sound quality while doing it. All ported by the way.
Thanks guys. But im planning on running it with the Audiopipe AP1500. Since the SSDs are 800 ea and sa's are 600 ea i should just get the sa's?
Both are rated conservatively. A properly set up amp and you should have no problems with either.
Loudest isnt at all judged by the sub. its mostly judged by the car and the box. Thats something to remeber.
They are not really the same, the SA is a 2.5" coil IIRC and the SSD is a 3" (someone correct me if I am wrong). Take a peak at the spec's and figure out if you need the increased limits of the SSD's.
