Leon Tan
XS Power D375 install questio
i just got my hands on a XS Power D375 battery, now im figuring how to hook it up to my system? battery postive to battery positive? i just need a little help with the install. i just dont want my car to go up in flames. :fing34: anyones 2 cents will be helpful.
would i need a fuse inbetween both battery to batttery? and secend battery to amp? no?
Fuse within 18" or so of each + battery terminal, either way. Just to be safe!
On any wire passing from the engine bay to the back of a vehicle always fuse the wire from the front battery.
When hooking up 2 batteries, positive to positive and negative to negative is the correct way to wire.
ok thanks, would i need fuse inbetween 2nd battery and amp? or would it be fine with the amps 2 70 amp fuses? jw
