swift 501 Posted June 29, 2012 I ordered two FT1 4ohm tweeters and two PWX-8in mids 4ohm.Well the 8's that came are 8ohm.....Should I try and make this work or just send back for the 4 ohms?The amp is a Alpine PDX 4.150 and does rated at 4 or 2 ohms. 0 Share this post Link to post Share on other sites
ricksi30 923 Posted June 29, 2012 You could just use them, but personally I would want them switched out. 0 Share this post Link to post Share on other sites
95Honda 486 Posted June 30, 2012 You will have better fidelity with the higher impedance, with the cost of a small amount of output... And I mean a small amount... Little enough that you would probably never notice... 1 Share this post Link to post Share on other sites
ricksi30 923 Posted June 30, 2012 You will have better fidelity with the higher impedance, with the cost of a small amount of output... And I mean a small amount... Little enough that you would probably never notice...Okay so I always knew it wouldn't make a big difference, I didn't realize just how insignificant it would be. Thanks for posting! 0 Share this post Link to post Share on other sites
///M5 2,833 Posted June 30, 2012 I'd rather have the 8 0 Share this post Link to post Share on other sites
///M5 2,833 Posted June 30, 2012 Or to say that differently the 4ohm option is stupid 1 Share this post Link to post Share on other sites
EpicenterDesigns 26 Posted July 2, 2012 (edited) Sorry about the mix up.If you want to exchange them PM me and we will take care of it. Edited July 2, 2012 by Epicenter Jon 0 Share this post Link to post Share on other sites
swift 501 Posted July 2, 2012 Or to say that differently the 4ohm option is stupidHmmm, I never knew. I did know my previous components were 4ohm and I also believe my coaxials are too. I figured I was ordering right. Thanks for the tip 1 Share this post Link to post Share on other sites
