KyleBrown
Port ideas
So I've decided that I don't like this 38-39hz tune at all.
We have 9.5 cubes (after disp)
current port is a 12.5 sonotube @14.5" long
I can maybe stretch it 17" maybe, but all that extra port will be external. But that's only 36-37hz
12" doesn't help much either...
If I can find a 11.5" sonotube I can get to 34hz @17" long
12.5"=122.6sqin of port=12.9sqin per cube
11.5"=103.8sqin of port=10.9sqin per cube
Most people's rule of thumb for round to slot port is 3-4"
so 12.9sqin per cube =15-16.9sqin per cube
10.9=13-14.9
So what do you ladies think?
Edited by armykyle1
Can't read that at all on my phone. :(
Dont see why it wouldnt work, try it out! Worst thing that will happen is that you still dont like how it sounds and need to try again? :)
Port area per cube is a joke (most of the time). You must calculate minimum port area per the driver(s) used and the desired tuning. Internal area doesn't matter either.
Yes^^. There is no realtion between enclosure volume and vent area. Power and driver displacement are the dominant factors. You need to model to find out what the vent velocity will be.
What drivers, amp, and "wiring down to?"
I'd pick some tuning point, and calculate the vent mach for xxx port area. If vent mach is too high at xxx port area, and you can't increase port area due to port length constraints, then consider upping the tuning point until you find a happy medium.
Edited by stefanhinote
They're custom ufo BTL 18's with Zv3 sofparts. D1's
series/parallel to 1ohm. They'll be on a single DC5k for a short time then two DC5k's strapped @1ohm.
I've tried modeling the subs but keep getting errors.
The only TSP's I have are
(series)
SPL- 92.391w/1m
R(e)- 1.834
Fs- 34.99
Q(ts)- .41
Q(es)- .44
L(e)- 3.171
M(ms)- 306.1g
V(as)- 4.071cuft
I would put xmax in the 28-30 ranger since stock is 28mm but these coils are slightly longer.
I came up with:
For two of those drivers with 6kw with 35hz tuning:
100in^2 vent mach 48.275 m/s / 0.14
130in^2 vent mach 37.135 m/s / 0.108
150in^2 vent mach 32.183 m/s / 0.093
180in^2 vent mach 26.82 m/s / 0.078
200in^2 vent mach 24.138 m/s / 0.07
215in^2 vent mach 22.454 m/s / 0.065
I came up with:
Which program are you using?
I came up with:
http://portsgalore.s...om/?do=ventmach
The aero port section doesn't account for any flaring, just circular port area.
You can try it along with winisd.
Also note that vas is in liters, not cubic feet, so you'll have to convert that.
Thank you. I didn't even look at that at first.
Looks like I'm going to give an 11" port a shot with the step down in power. Plus I'm thinking about getting some of those sa/oa 18's built. Need lows :)
Looks like I'm going to give an 11" port a shot with the step down in power. Plus I'm thinking about getting some of those sa/oa 18's built. Need lows smile.png
You're going to switch from what you have to Sa's? Sounds like a bit of a downgrade.
Just saw your post about the shifted motor :(
It shifted on the basket. Noob mistake. Used washers for spacer and loctite on only one screw.... Drinking and sub building lol. I already paid for parts to rebuild it.
The SA/OA 18's should offer better low end and might perform better on the DC5k. I might have Nick use SPL coils, not sure yet. But I want then low lows :)
