bigken817
(2) AX1000, (3) single voice coil subs
Hi guys, last weekend I picked up 2 of the US Amps AX1000 (for now), and I'm using them to run (3) 2 ohm Cadence Wild Beast subs (for now).
How do you strap the amps together without using the magic "MLT" box?
Under the plexiglass, I can see the "master/slave" switches for both channels, but I'm a little leary doing anything to the circuit board without some instruction.
Down the road, I'm planning on adding at least 2 more AX1000's and one more sub, but this current set up will get me thru the week.
Thanks, in advance
oh okay THAT i can help you out with. set one amp to "masteR" and set one to "slave" when you are setting gains, all you need to do is set the master amps gains and you are good
