jrouter76
1.0 cuft of space
I have built a boxthats tuned to 32 hz,after port and spkr displacement i have 1.0 cu.ft of space left, my question is will this work or will i need to build a different box this is a dual ported box and it is for 2 12 mags new version....also if this will not work how about a sealed dual chambered box with each chamber @2.2 cu.ft.,will this be to big sealed? btw the amp is a DEI2400D(1400watts @ 4ohms, 2400watts@ 2 ohms)
1cube for two 12s ported is not enough space
2.2 cubes sealed might be a little much, but if you have that much space why not go with a large imported
thats 1.0 cu.ft per sub and if i go sealed that 2.2per sub
Anything over 1.5 cubes sealed will gain you nothing. As far as vented is concerned, I PESONALLY, would not go anymore than 2.4.
