extremeVFT03
custom fi BTL
there is no need for a dual 4 really. what ohm load are you shooting for?
you can get .5, or 2 from the dual 1.
or 1 and 4 from the dual 2.
a dual 4 would get you either a 2 or 8 ohm load. you can get the 2 from a dual 1. and 8 ohm is normally only used in home audio.
but you never know. email them and see.
As stated above, a dual 4ohm really isn't needed.
The dual 1ohm and dual 2ohm versions cover all necessary +12v impedances.
nG
you be better off selling that amp and using the money to buy 1 large amp.
i speak from experience. i did something similar using 2 4 ohm amps on a large woofer. i set the gains with a DMM so they shouldve been really close. but there were differences in the amps and one side was over powered which killed my sub's surround a few months later.
but hey, recones are cheap. do what you will.
i need dual 4 because i plain on runin one amp to each vc and my amp does 1000 rms at 4 ohms briged
Unless you can strap that amp, thats usually not a good idea for a daily driver setup. And if you can strap it, you should bridge it at 8ohm if they are 4ohm stable and 4 ohm if they are 2 ohm stable.
If you need it for spl, you need new amps that make more power. imo
why not dual q's or ssd's?
Edited by dopey
