Aaron Clinton
T/S Parameters
Here are the T/S Parameters we promised:
ICON 10" SUBWOOFER
DUAL 2 OHM COILS
Re 1.5 per coil (specs measure in series 3.0)
Fs 30.7
Qms 5.60
Qes .41
Qts .38
Mms 190 g
Sd 310 cm^2
Vas 19.1 l
Bl 16.4
Spl 83.1 1W/1m
Xmax 20.5mm
Wattage: 1000RMS
Displacement: 0.12cuft
ICON 12" SUBWOOFER
DUAL 2 OHM COILS
Fs 29.9
Qms 5.87
Qes .45
Qts .42
Mms 212 g
Sd 480 cm^2
Vas 43.7 l
Bl 16.4
Spl 86.0 1W/1m
Xmax 20.5mm
Wattage: 1000RMS
Displacement: 0.16cuft
ICON 15" SUBWOOFER
DUAL 2 OHM COILS
Fs 26.4
Qms 6.01
Qes .48
Qts .45
Mms 262
Sd 810 cm^2
Vas 127.8 l
Bl 16.4
Spl 88.7 1W/1m
Xmax 20.5mm
Wattage: 1000RMS
Displacement: 0.19cuft
Is dual 2 the only VC configuration?
For now yes.
Again, that 15" looks yummy. Qtc .707 looks to be around 3.0 to 3.25 cubic feet.
What I want to know is what's the mounting depth for the 10" and 12" Icons. My Massive Audio P1000.1 amp does 880 Watts @ 1 ohm, so the power is already taken care of.
10"=6.5" mounting depth, 12"=7.0" mounthing depth
I just want to verify. On the website, it says the 10"=6" mounting depth, and 12"=6.5" mounting depth.
7" is to much for my app., so I was thinking the 10" sub, but now I can do the 12" if the mounting depth on the site is acurate.
Thanks.
BTW: Who do I ask to get a shipping quote to get one of those to Honolulu, HI 96819?
Edited by king alpha
Thanks.
so sorry, the site info is correct
pic deff could be clearer, but I have lighting issues, anyways, hope this helps
went ahead and changed the RMS of the ICON to 1000wRMS, since we all will agree that they won't even break a sweat at that wattage. :)
i was worried at first about the rms because im going with 2 kicker 2500.1 and putting 1250 into each sounded a bit much..but after reading more i think i'll be ok with 1250..
Should be just fine with that. :drink40:
