Mega Heavy Bass
New Vectra Box with Old BMs - very impressive stuff
Hello all.
Hope you`re all doing fine ;)
I strill haven`t had a chance to alter the Escort install.
But I have been messing about with my vectras boot install.
Check this out:
See this weird box...
6th Order bandpass or simply a tunnel in a boot.
This box is far better than any box I have ever made :o
It plays low.
It plays loud.
It plays a very wide musical frequency with accuracy and is practically flat in it`s overall frequency response.
O.K. The system specs.
Vectra Sri - Boot System.
1x HMM Box- That`s what I`m calling it - After the ideas from a guy called Henry & Mazdawg & Me making the thing to see what happens.
1x SPLd S-1200d (1200wrms @ 1ohm)
2x Brand new - Stereo Integrity 12" Baby Magnums (500wrms power handling per sub)
1x 70Ah Leisure battery
1x Sony Cheapo Head Unit
THE SCORES :thumbsup:
Using only 1200wrms of power this system does the following.
((((Propper Droppers))))
Total Average Score = 141.4dB (I`m confident this score will get louder... )
Peak Freeq = 142.8dB @ 22Hz
40Hz= 140.3dB
33Hz= 140.0dB
25Hz= 141.2dB
20Hz= 142.7dB
10Hz= 130.7dB
And I tested it using the dB drag rules too.
Readings taken from 60Hz downwards + the ((((Propper Droppers)))) SPL frequency format.
60Hz= 138.0dB
55Hz= 140.3dB
50Hz= 141.7dB
45Hz= 141.7dB
40Hz= 140.3dB
33Hz= 139.9dB
25Hz= 137.9dB
20Hz= 136.5dB
Is that good stuff or what!!!! ? ? ?
Don`t forget my last ported box need 2500wrms to hit the same sort of dB figures.
The ported box never played over such a wide frequency range either.
This box is doing more or less identical scores using.
Only 1200wrms. Half the power of the previous system!!
Over a much wider range of frequencies.
Edited by Mega Heavy Bass
Very nice work.
Damn, those are pretty impressive scores.
Crazy scores.
Did you receive some special BM's ? :lol:
