sqjeep
Help making your own rcas
I was wondering if this cable would be good to use for making custom rcas ?
here are the links...
PartsExpress 2
PartsExpress 1
If you know anything better can use list the site?
Attn mods Im thinking this should be moved into the general section for better traffic...
Edited by sqjeep
I was wondering if this wire would be ok to use to make custom rcas??
Here is the links...
Dayton MLI
Dayton MSC
P.S I know i made two topics about this but i placed it in the wrong section so if a mod could combine the two that would be great (Its in the techincal section)
Sorry and thanks
Dayton MLI
Dayton MSC
Sorry and thanks
Just a shot in the dark, why make your own rca's?
i didnt click any of the links...
but i have made my own RCAs many times..
you can go to radio shack and get the rca ends,. you can use like 18 or 20 gauge wire... thats much thickers then most RCA leads you buy on the market,.
Dayton MLI
Dayton MSC
Sorry and thanks
For a custom fit and it supposed to be cheaper and better than buying rcas
Bigjon are use saying i could jus use speaker wire??
Dayton MLI
Dayton MSC
Sorry and thanks
Cool. I might look into that myself, thanks! :)
Dayton MLI
Dayton MSC
Sorry and thanks
Your welcome. Anybody else have done this and can give some insite??
Look on Ebay for some Streetwires RCA ends. You should be able to buy them in bulk from someone. I have a ton of these things. I also happened upon 4-250' rolls of Tiff RCA cable and have been using this to make my own for every install since 2003.
How good is that Tiff stuff??
Any noise from your cables??
Also how is it per foot??
It's all good. NO noise from any cables I've ever used, even the cheap stuff. Don't believe all the hype. If you do everything properly, noise will not be an issue.
some of the cables have a drain wire, do i connect with the ground wire on both ends?? Or do i do it on the headunit side and take the other side and ground it to the chassis??
Either side, but it's not really needed.
Some good reading material there :)
Thanks Adrian_D that was good reading. Now I need to find some good cheap rca ends.
How many do you need?
7 left and 7 right, or 14 of each channel?
Sorry
7 left and 7 right
PM me your shipping info and I'll send some out to you this weekend.
