Dexter Chaos
Zcon box sizing
I am purchasing 2 zcon 12. Are the box specs givin for these net or gross volume?
Optimal allows the driver to perform it's best. Always shoot for optimal. If you cannot fit optimal I always just go down a driver size so I can fit optimal for that driver.
Try to get at least 5 cubes net for the pair. Also try and get at least 100in2 of port area too.
Give the drivers what they want and they will be happy. If you need help designing an enclosure let us know and we would be glad to help.
Edited by mlcantin
Maybe I need some help. My current design is 5 net but I am only looking at 80sq inches of port.
The specs are after driver and port displacement.
Put down your max dims and i see what I can get.
Also what tuning do you want and how much power are you using?
Edited by Bassink
*.*+++++++++!~current box is designed as a two part with finish assembly once installed it is 37wide x 34 deep x 13 high.
Here is pic to show where I made the split to install into my trunk space.
I could make it taller but would have to more trunk assembly of enclosure.
Originally I wanted to put the port in the center which Could give me more room to achieve the 100 sqin port area. I was advised to keep it simple for my first box design. It appears I needed more help than I thought.
Is the 80sq in of port going to cause a breathing issue for these subs?
I would start over with my box build if the 80sq in of port area will cause  an issue.
after seeing Frog
I can
Ehh 80 isn't bad but I would definitely go with more. I have 68in2 for my single 12 Zcon. I did have 40 for my first box and it did work good. Try it out and see how it is, you should be fine. I thought you didn't have a box built already.
i believe frogcase2002 is running 80 sq inch i believe.
I have no problem building a new box.
I could use a height of 15 if I had chosen to build more inside of my trunk. please advise or give me some drawings I realized I could use the help. Constructive help I will accept to better suit the subs I have ordered.
So you can have a height of 15 with all the other dimensions?
He is using 80 but I think he said he was gonna put more.
Given the xmax of the sub and assuming tuning is 32 hertz (didn't see it listed). 80 inches is plenty fine.
