MKader17
1998 Nissan Maxima
This is a build log for TMAX's 1998 Maxima, but since I have all the pics on my digital camera I thought I'd start the build log.
The components to this system include.
Head Unit
Pioneer Premier 880 PRS
Front Stage
LPG Tweets Powered by a Kicker 100.2 with Seas 7" Mids Powered by two channels of a Kicker 850.4 (I can't remember the exact models so I will comeback and ninja edit when I do. I'm pretty sure it is exactly what ///M5 is running in his Silverado)
Substage
2 Sundown 10" SD-1's powered by the other two channels of the Kicker 850.4 bridged to 4 ohms
Deadening
2 Rolls Raamat BXT and 6 Yards of Ensolite which will be focused on the front doors and the trunk
Day 1
After a bunch of planning buying talking and BS'ing about the system we finally got it started by deadning the trunk.
First we stripped to the bare bones
Prep/clean the trunk for a good stick
The stock deadning
The Goods
Always a great phrase to see :)
Michael (me) working in the trunk
Our High Performance cutting board
Travis (TMAX) getting under the rear deck (or probably napping)
Rear deck complete and Rear fill FTW!!! j/k ;)
The trunk is dead
This is all we had left of the entire roll when we got finished
:woot: for a great day. More install and pics to come soon
*UPDATE* January 1st 2008
Got the Head Unit installed and the RCA's ran today!
The Stock Setup
Got Everything thing tore down. Had a problem with getting the hazard light switch unplugged so we just put the whole piece on the top of the dash and left it connected
Random Pic...
Had to custom fit a piece in the gap between the bottom of the unit and the pocket. The Scoshe kit provided a new pocket that only made it look worse
Remains of the piece that we hacked
Added a hole in the back of a pocket to run the Ipod connector into a sweet little spot.
Completed! Sorry about the quality of some of the pics, my digicam can be very finicky
New headunit is very nice and actually a lot more graphical then I expected. Under a quick listen the stock speakers sound a wee bit cleaner. Travis will be spending the entire night reading the owners manual lol. This is definitely a very involved headunit, but extremely nice
Lots of work done...
The Stock Doors
Raammat and ensolite on the outer skin
The monster baffles
Yes, 2 inches thick!
A little comparision
More woofer!
ARE YOU NOT ENTERTAINED!!!
Drilling for the power wire
Wires everywhere in the trunk.
Cut out for the tweetz
Some good deadning on the inner skin
Add some Ensolite and the monster baffle
Getting Close to completion! The tweetorz are happy
Some deadning on the panel to stiffen it up a bit
Install the Woofa!
Woofa Installed!
The completed door back together!
Its been a long process but very rewarding. Now time time to ask alot of questions! I'll post them in a new post in a sec. Sadly the Ipod connector doesn't work but it will get fixed/replaced. Time to start EQ and TA and set the gains =)
Starting the sub portion of the install
mmmmm MDF
First Cuts
Stacked....
more construction
right chamber
right chamber
gettin close
moe peektas
mmm muscles lol
amp rack
looking good, now toss the rear fill
x2 on the rear fill :)
Love the equipment and carry on the good work
lol rear fill has been faded out for a long time and will be removed
ya rear fill is no more pretty much they are just blow throughs right now.
:slayer:
on second thoughts i may throw in some 800w 6x9s right mk lmao!
its moving slowly but surely
and we hit a bump in the road after everything was installed i tried to hook up to my ipod connector i got power to it but now sound? hrmm... and i notice upon install that the product i bought was a refrub which i thought i was buying somethin brand new but maybe i miss read that part. but in the end its not working properly right now :(
oh well cant have everything go alright. still need to try it with my ipod and maybe it will be gravy crosses fingers.
i would of started on the doors today but mk has to go shoot some guns so he can get ready for his south texas hunt! oh well lol there is always tomorrow.
and the headunit is real sweet just got done messin with it lol
Looking good so far.
Updated!
What kind of crossover points should be started with for the tweets (25NFA LPG 1") and mids (CA18RNX 7")? High pass and low pass)
How much power would you throw at the tweets?
How long should the Woofers be broken in for?
Without the use of an oscilloscope do you believe the setting the gain with DMM is sufficient. (with some use of ears and common sense)
How do you like it?
finally the doors are done!
it was a long days work and wouldn't have been that long if things did mess up
but what is the fun in that.
now for the programming of the headunit and to work on a box for sd1's v1
lata guys its night night time peace! :slayer:
Updated!
How do you like it?
Start at 5khz+ on the tweet and 3.2k- on the woofer and work your way up and down playing with slopes.
Set the gains on the mids, listen to them alone and then fade in the tweeters by blending the gain with your ears. Do so at moderate listening levels, then be nice and turn off the mids and turn up the tweets and see if they are struggling...they shouldn't even with a bunch of power with at least a 12dB slope at 4k+.
DMM is fine as long as the amps you are using do rated power. ;) Ears are better though.
Install looks nice so far...don't be afraid to use some clay & deadening closer to your monster baffles (which I love btw). :fing34:
thanks sean
the baffles are sort of a lil to large for the door lol we had to do some more moding when we installed lol
but it works thats all that counts and i didnt break anything! yes lol
now to get me a new ipod adapter
Hey theres nothing wrong with that IPOD adapter. its an easy mistake on those pioneer headunits. Switch out the ends of that funky cable that goes to the back of the HU and connects to the ipod box. I had the same thing happen to me.
If it makes sense you want the end thats connected to the ipod box on the back of the HU and the end connected to the back of the HU on the ipod box.
Edited by thacarter546
alrighty i will try that when i feel like taking the dash apart again lol
but will definately try it out
thanks
Make sure you do it before the 90 day return period so you will still have time to return it if it is broken.
Have you set the crossovers yet? just curious, and when i get to Beaumont we'll pop in that test CD and throw that DMM on the amp to get the gains set
on day 58 so i got time lol
and i havent messed with anything but give the mids a lil more power :)
*Updated 2/3/08*
Started to glue and screw the box. I have to say the pieces are very precise
