rattlebox317
which sub need your input plzzzzzzzz
High quality long-throw subwoofer suitable for home and car audio
Use high Qt version for Infinite Baffle setups
Cast aluminum basket
3" high temperature voice coil
Triple stacked motor
Enhanced motor cooling
2 layer spyders
Your choice of dual 1 Ohm or dual 2 Ohm configurations
Can be optimized for Bass Reflex (low Qt) or Sealed (high Qt) boxes
Suitable with amplifiers of up to 1000 watts RMS
Shipping included in price
(within North America)
Power Handling - 1,000 watts
Sensitivity - 86db (2.83 volts)
Impedance - Dual 2 / 1 Ohm
Dimensions
Outside Diameter - 31.1cm
Mounting Diameter - 27.9cm
Mounting Depth - 16.5cm
Recommended Box Sizes
Low Qt Models - 40L (1.4 cu. ft.) 30Hz tuning
High Qt Models - 50L (1.8 cu. ft.)
T/S Parameters
Dual 2 Ohm Version
Qt = Low / High
Fs = 26 / 26 Hz
Re = 3.7 / 3.7 Ohms
Qes = 0.32 /0.74
Qms = 6.24 / 8.58
Qts = 0.31 / 0.68
VAS = 34 / 44 litres
Sd = 411.9 cm2
BL = 21.8 / 12.6
Xmax = 22 mm
T/S Parameters
Dual 1 Ohm Version
Qt = Low / High
Fs = 29 / 29 Hz
Re = 1.8 / 1.8Ohms
Qes = 0.45 /0.75
Qms = 6.24 / 8.01
Qts = 0.42 / 0.69
VAS = 32 / 28 litres
Sd = 411.9 cm2
BL = 12.3 / 10.5
Xmax = 22 mm
or
Death Row Series 12"in
• 8 spoke black cast basket
• 3” 4 layer flat wound aluminum voice coil
• Double Black Progressive Spiders with Woven Tinsels
• Injected Pulp Matrix Fiber Reinforced Cone
• Double Layer Foam Surround
• Triple Stacked Magnets with Black Nickel Finish
• Interlocking Aluminum Spider Spacer Assembly
• CILD - Center Interlocking Dustcap
• ADC - Air Driven Cooling
• Nickel Plated Push Terminals
• Wrap Around Rubber Gasket
• 1000 Watt RMS Rated
• DVC 1 ohm or 2 ohm
read noob post guide lines. we need more info.
ok i have a 2001 old alero.... these two are the subs i have bine looking at ........asking with one is better really , looking for low bass good quality sub, look at the price diff or do you have any input on 2 12" subs that will hit harder for under 500 for 2
With so many annoying spelling errors I had to at least change the first word in the title. And if you don't give more specific system goals than good quality and hitting hard this will be locked.
Otherwise just flip a coin.
x2, thats what I did in deciding what I wanted (I just flipped a coin).
We got it and gave you an answer on the lack of information giving. Regarldess both subs are good and there is no best out of the two, if so the inferior one wouldnt be still selling. Now which sub is better for you application is another question and all that depends on your system and goals.
There arent any bad subs on this forum; just get one that: fits in your budget, power range, enclosure size space availability and so on.
The DRs are $320 a piece so thats $140 over the $500 budget to start. These 12" AQs would be right in your budget.
Audioque HDC
But I think I would choose 2 of the IXL12s if it were me.
i was asking witch sub was better but guess u didnt get it ..
Dude, you need to get firefox. It has a spell checker. This is getting annoying. Your sentences are horrible and the words you spelled wrong are almost elementary. I usually don't care about slang and internet shortcuts but sometimes it is too much. Please download firefox and install it.
But on the subject, I think the HDC3s will get louder but the iXLs will sound better. Chop has heard the 10" iXL I built for my girlfriend. Ask him about it. And Enellz has the HDC3s. I think he heard them too. Also I think the HDC3 want to be in bigger boxes compared to the iXLs. If you are going to get the HDC3s, I'd get them soon because that price is for a limited time, for customer appreciation sale. I think the Mach5 prices are in Canadian dollars so it will be cheaper in US dollars.
Rattlebox, the next time you post on this thread it better be to make this thread fit within the guidelines of the forum. And don't add any attitude to it either. Again you have been told twice by other people in this thread the right way to get help, but again argued and aren't following the guidelines or the forum. You already know what happens when you argue a third time.
If you have forgotten, you can read the three threads in my sig.
