blunt
2 Fi Audio SSD12
I need an enclosure for 2 Fi Audio SSD12 (Dual 1).
This is going in a 2010 Dodge Charger.
MAX size would be 32"w x 15"h x 20"d .
What do you recommend and how much would that run me?
Sub Info:
DUAL 1
Sealed box: .7-1.2 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 6.500”
Displacement: 0.14cuft
Edited by blunt
Using your max dimensions I was only able to fit a 3.6 cube enclosure, but the width would have to be 36.5, 15 tall, and 20 deep.
Let me know if you can get away with 2.5 more inches width.
Andrew
it's set at 32" i think. the depth could change a bit tho. would that help?
p.s. thanks.
Edited by blunt
the height and width are pretty much set. unless i do some major mods on the trunk. How much does the depth have to increase to make it work? And can you quote me the price for that enclosure? thanks andrew.
I think i could go with 22 on the depth. What are we looking at for prices on the enclosure? Do you recommend ported or sealed for those subs?
If you go with sealed you could get three in there... I think I am going to go for straight cone area.. which would be 3 12" SSDs in a sealed box firing forward.
Edited by Hell-Razor
andrew, so what are we looking at for a price on the ported box that you worked out? You still have the 15% off going on right now right? Thanks for the help.
Ok with the dimensions of:
22 deep
15 tall
32 wide
I can fit the min recommended by Fi. Your looking at $153.00, that is with the 15% off.
Andrew
I'm excited to get this thing. Ahh. I'm getting my subs tomorrow from UPS. :bigok::woot::dancing:
Big ups andrew. this thing looks great. can't wait to get it installed.
Glad to hear you got your box dude! Now it's time to get some pics of everything and the build log going!! :drink40::fing34:
