808kikdrum
Advice needed! outdoor subwoofer and enclosure.
Need some advice\input, Looking to build an outdoor\patio subwoofer enclosure and find a suitable subwoofer to put in it. I am completely new to outdoor audio, my initial thoughts were a marine subwoofer and a birch box doused in resin and truck bedliner? Again, TOTALLY new to all of this so i may be way off. Whatever the sub and enclosure material, they will both need to stand up to the very muggy, hot central indiana summer weather. Sealed or possibly PR enclosure, Will be powered by a dayton 150 watt amp. Any and all input is greatly appreciated, thanks.
Do you need a fair amount of output? I ask because outdoor audio really takes a hit on the bottom end. You don't get any room gain...
Most outdoor subwoofers I have built have been vented, most 4th order bandpass and horns. I would stay away from a sealed alignment, unless of course you aren't worried about output. Honestly, 150 watts and a single driver in a seale dbox won't go really far.
As far as the enclosure, is it going to get humidity only or get directly rained on? If it is just humidity, you can use most materials if you build it right.
My in-laws have a set of 2-ways mounted above thier hot tub in a sun room (green house). I used Adire 4.5" midbases and Audax tweeters. It is a vented alignment, so air can get inside the box. The boxes are MDF, but I primed the inside with 3 coats of Dupont snadable primer and the outside is finished with Formica. I also used stainless mounting hardware and gold plated terminals. Everything soldered and the joints were cleaned and coated with conformal coating. It has been almost 8 years, the only thing that has changed is the copper phase plug on the Adire drivers isn't as shiny as it used to be, not turning green, but opaque looking...
For a sub, look into a lab horn if you have the room, build it out of marine grade plywood and get it shot with line-x.... You could spray it with a hose every day and it would be fine...
Hope this helps...
Thanks for the response! It may see some direct rain, only if it gets truly gnarly outside, which tends to happen in indiana summer thunderstorms. The constant humidity is my main concern, its sticky as HELL here. I want to go ported but theres so many bugs and various critters that would love to make a home out of a nice enclosure that it concerns me, are there port grilles or meshlike materials that exist that wouldnt impede the airflow too much? As far as output, not looking for anything major. Listening area is only about 15ft by 20ft(patiodeck) and neighbors wouldnt tolerate anything more than moderate listening levels, old f'ers. Im confident i could make the enclosure pretty impervious to the elements, its mainly the sub that im concerned with. Is a marine sub a silly thought? My plan was downward firing, under a bench thats back is against the house, mostly under the roofline. it would be relatively protected but i dont see it escaping direct water exposure on at least a few occasions.
If you don't need a ton of output than you would be fine doing a standard vented or sealed box.
Don't need a marine driver for th emost part. Just look for something with a rubber surround, poly/aluminum/heavily treated cone and preferably an aluminum frame. Look at one of the Dayton HF 12s....
You could use something like window screen if you want to keep the bugs out...
I would do a down firing 4th order design out of birch. Spray with bedliner and it would be fine.
Similar to this, one I thought of right away and one I found searching online
I would have the opening recessed like the one I drew so water would not run in the opening if it did rain.
post-12451-0-90368900-1332946896_thumb.j
post-12451-0-54212700-1332946906_thumb.j
Edited by swift
I like that 4th order, id rotate to have the port firing down, raised up on some feet. thanks for the input!
yeah but its bets not to see the driver through the port in a 4th order BP
    1. Recent Topics
        • 19 comments
        • 326 views
        • 3 comments
        • 80 views
        • 398 comments
        • 33,435 views
        • 4 comments
        • 165 views
        • 2 comments
        • 741 views
        • 5 comments
        • 1,585 views
  • Similar Content
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      A brief introduction to the all new SSA Demon, but first a farewell to its predecessor.
           Our very long running SSA Dcon has ridden off into the sunset, or at least taking a breather.  The SSA Dcon was our second subwoofer model we ever launched.  At the very beginning, we had the Icon and as it gained traction we saw there was a need for a pure SQ sub of more modest power rating than that the Icon.  So in early 2008, the first SSA Dcon was launched.  (The Xcon followed shortly after).  That being said, the Dcon was almost an immediate hit, with a long 2" copper coil (rarity to have one made in the USA) triple stack motor, rear vent.  The Dcon was very affordable, well made, quite efficient, clean across the entire range, and flexible with enclosure demands.  It is interesting as there are some SSA Family members who swear by their Dcon and will not give it up ever.  (It even became a favorite of some of the home audio crowd).  All that being said, the Dcon evolved a bit for its second generation, we made a leap forward in motor force moving to what is best described as a scaled down Xcon motor, with a large single slug, solid pole, and deeply bumped back plate, while beefing up the suspension and leads.  We were able to bring the power handling up 33% while not hurting the sound that made the Dcon successful.  There was a stretch of a few years, before we ran out of stock, that the SSA Dcon 12 was our all time best selling subwoofer.  So its existence was very important to SSA.  Well with changes in the market (read:customer demands and amps getting much cheaper), as well as sky rocketing material costs, building the Dcon in the USA no longer was an option, so production stopped early 2017 for both the Dcon (and Gcon) and inventory ran out later that year.
           Late last year, due to the long lay off with out the Dcon (and Gcon), we started development of an updated Dcon at a new build house.  The quality and performance of our SSA Evil1 tweeters were above our expectations, so we decided to send more production to that same build house.   As we saw that the market slowed overall for modest power rated subs due to power getting cheaper and people wanting higher power handling subs, so the market began to really start heating up in the 500 - 1200 watt range, I knew we needed to address it.  There is an 8" model developed, but it will not make it this first production run.
           The new model had to handle more power and have more xmax while not sacrificing the balanced and clean sound the Dcon had established for nearly a decade.  That meant larger motor, larger coil, more suspension, larger leads, thicker cone, taller surround, etc.  In the end, all of the changes that happened to the over all design, we could no longer call it a Dcon.  In sticking with the theme of the Evil, a model name that has become so well known, while respecting the Dcon, the Demon name was selected.  The Demon is a great blend of the previous Dcon and Xcon, both in design and appearance.  In prototype testing, the SSA Demon thrived smaller to mid-sized ported and mid-sized sealed enclosures.
      Quick SSA Demon stats:
      2.5" copper coil Aluminum former Aluminum Shorting ring Solid pole, non-vented bumped back plate Large single slug motor Pressed pulp cone Tall roll surround Push terminals Dual Nomex progressive spiders Stitched tinsel leads Large dome dustcap I will list T/S specs and enclosure recommendations shortly.  We are very excited about the SSA Demon as it bringing back to our line up a pure sound quality subwoofer that will be affordable, while still having the characteristic SSA warmth and output.
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
  • Recent YouTube Posts
