Robert Christman
Subwoofer Dilemma!!!!!!!!
Have you considered zcons? What is it about the xcon that has you interested in them?
well i really dont want to put out more money then what the truck cost me im looking about $2200 i bought the truck used for 4k i mean if i wanted to spend that much for 4 subs i would but two smd 18s
No you wouldn't, they are discontinued
Got to look around just in the matter of your last post i found 4 of them
But is anybody going to answer my last post about the box and the size
What do you want to know? Your first post isn't exactly easy to read.
Do these subs like  a open box like 48wide 18 tall 28deep
That's 14 cubic feet total. In that space I would do two 18s. That is not the same dimensions from your first post
Well you said properly designed and built enclosure i dont want to big 4ftx4ftx2ft is kinda big for that sub i would think Edited by bass4life
i think thats somthing like  25 cubs
For which subs ? your posts are all over the place.
How many subs?
What size?
Which subs?
48x48x24 is 32 cubic feet, which is huge
Need to figure out what subs your going to get then have the enclosure designed for them
im stuck i like the xcon 15 and the gcon 15  and im wanting 4 of them
Also i build my own box's
for 1088 i get 4 gcon and xcon are almost 3k
price for 4
Edited by bass4life
I'm asking what amplifier you have?
For 4 fifteens, you will want 16-20 cubic feet before port
I dont have any till i get the subs then ill buy the amps to match i will buy 2 amps to power 4 subs
Decide on how much power you want to run. There's a huge difference between the two woofers power handling. 3000w for 4 gcons or 7000w for 4 xcons
More power is going to cost you more in wire, batteries, alternators, etcetera
ok so a 18x48x48
Should price out some amps and batteries before deciding. Your going to see the subs probably won't be your biggest expense.
ok so a 18x48x48
Yeah that's 24 cubic feet
i got 3 batts Kinetik KHC1400 old but they work and the big 3 already
Edited by bass4life
This is a great post, you need a total budget. Woofers are just a small chunk of the budget.
    1. Recent Topics
        • 400 comments
        • 34,224 views
        • 19 comments
        • 390 views
        • 3 comments
        • 113 views
        • 4 comments
        • 223 views
        • 2 comments
        • 767 views
        • 5 comments
        • 1,621 views
  • Similar Content
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      A brief introduction to the all new SSA Demon, but first a farewell to its predecessor.
           Our very long running SSA Dcon has ridden off into the sunset, or at least taking a breather.  The SSA Dcon was our second subwoofer model we ever launched.  At the very beginning, we had the Icon and as it gained traction we saw there was a need for a pure SQ sub of more modest power rating than that the Icon.  So in early 2008, the first SSA Dcon was launched.  (The Xcon followed shortly after).  That being said, the Dcon was almost an immediate hit, with a long 2" copper coil (rarity to have one made in the USA) triple stack motor, rear vent.  The Dcon was very affordable, well made, quite efficient, clean across the entire range, and flexible with enclosure demands.  It is interesting as there are some SSA Family members who swear by their Dcon and will not give it up ever.  (It even became a favorite of some of the home audio crowd).  All that being said, the Dcon evolved a bit for its second generation, we made a leap forward in motor force moving to what is best described as a scaled down Xcon motor, with a large single slug, solid pole, and deeply bumped back plate, while beefing up the suspension and leads.  We were able to bring the power handling up 33% while not hurting the sound that made the Dcon successful.  There was a stretch of a few years, before we ran out of stock, that the SSA Dcon 12 was our all time best selling subwoofer.  So its existence was very important to SSA.  Well with changes in the market (read:customer demands and amps getting much cheaper), as well as sky rocketing material costs, building the Dcon in the USA no longer was an option, so production stopped early 2017 for both the Dcon (and Gcon) and inventory ran out later that year.
           Late last year, due to the long lay off with out the Dcon (and Gcon), we started development of an updated Dcon at a new build house.  The quality and performance of our SSA Evil1 tweeters were above our expectations, so we decided to send more production to that same build house.   As we saw that the market slowed overall for modest power rated subs due to power getting cheaper and people wanting higher power handling subs, so the market began to really start heating up in the 500 - 1200 watt range, I knew we needed to address it.  There is an 8" model developed, but it will not make it this first production run.
           The new model had to handle more power and have more xmax while not sacrificing the balanced and clean sound the Dcon had established for nearly a decade.  That meant larger motor, larger coil, more suspension, larger leads, thicker cone, taller surround, etc.  In the end, all of the changes that happened to the over all design, we could no longer call it a Dcon.  In sticking with the theme of the Evil, a model name that has become so well known, while respecting the Dcon, the Demon name was selected.  The Demon is a great blend of the previous Dcon and Xcon, both in design and appearance.  In prototype testing, the SSA Demon thrived smaller to mid-sized ported and mid-sized sealed enclosures.
      Quick SSA Demon stats:
      2.5" copper coil Aluminum former Aluminum Shorting ring Solid pole, non-vented bumped back plate Large single slug motor Pressed pulp cone Tall roll surround Push terminals Dual Nomex progressive spiders Stitched tinsel leads Large dome dustcap I will list T/S specs and enclosure recommendations shortly.  We are very excited about the SSA Demon as it bringing back to our line up a pure sound quality subwoofer that will be affordable, while still having the characteristic SSA warmth and output.
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
      Somewhat blown (sub still plays) Sundown X v.2 motor.
      $150 shipped!
      Basket included.
  • Recent YouTube Posts
