Ok, I was getting ready to order some 10 gauge Knu speaker wire. Then I called a friend and he said he had about 40 feet of 8 gauge Knu wire. My question is can I use the 8 gauge or would it be overkill for the power I'm running? I will be upgrading amps in the future so if I use the 8 gauge I'll be set.
Is there such thing as overkill when it comes to wire size? As long as it fits there are no negative side effects for using larger wire.
I'm not sure it will fit. Well I'm sure it will fit in the sub. I'll have to pull the amp and see. Plus it's that Knu oversized Ofc speaker wire.
Depending on your wiring configuration, It might be hard to fit more than one wire in your sub terminal. Even with 10 gauge knu I had trouble.
Since he already has some available just use the 8ga. Worse comes to worse you will have to trim to fit.
I use knu 8 gauge. and binding posts from parts express. works great for me
^ This
Oh, Steve you reminded me of something I need away to easily disconnect the box if I have to for some reason. Could you get me some more pics of your post and how you have them running?
Greatly appreciate it.
Edited by Fearz
Appreciate the link. I'm trying to figure out do you put a wire with ring terminal on one side and then I see the post has a push terminal on the other. I would guess one side would be in the box and the other out.
This will be the first time using these every other time we use those little push terminals like on cheap prefab boxes, but since I'm using bigger wire I need something different.
Edited by Fearz
Yep. I would do the ring terminal on the inside. That way the box could be quickly removed if needed.
Nvm
Edited by Fearz
this is where i get my sub wire from.... audiopipe 8 gauge... pure copper
http://www.ebay.com/itm/280755810616?ssPageName=STRK:null:IT&_trksid=p3984.m1542.l2649
That is a good deal, but the Knu will be free or $10 bucks because I'll give him something for it.
http://www.ebay.com/...984.m1542.l2649
i would go ahead and get the 8 gauge ;)
I'm thinking
If I buy two binding post I'll take the 8 gauge for the two positives and the two negatives and wrap the two negatives around a negative binding post and the two positives around a positive binding post and lay solder on top of the wires so basically the wire will be fused to the post. Then just run the wire to the amp on the outside of the box.
Y not just use two lengths of wire (one for each VC) from the back of the terminal cup to the VCs.
? I got the two lengths of wire then after that ?
Edited by Fearz
What it sounds like you are trying to get at, is that you are asking why he doesn't run the coils parallel instead of series. This would make the amp see about 1/4 ohm. Not many amps can handle a load like that.
But I could be mistaken. You could mean something entirely different. If you did, I am sorry, please rewrite it.
What I would do in this scenario, is run a seperate wire to each post from each coil that is going to the post like the diagram shown. At the binding post I would solder ring terminals onto the wires, and tighten them on the back of the binding post with the nut supplied.
Exactly what I'm going to do.
I will look into these.
Would these be used to go into the amp or ?
Edited by Fearz
And thats what i get for posting late at night. I didnt read it too well. But it could have been done that way. One pair of wires coming off the negative side from the terminal, one goes to the positive on one VC of each sub and the other goes to the negative to the other VC of each sub. Then just connect the left over positive and negative. I was trying to avoid using another terminal by just stack ring terminals at the cup, your right i was thinking parallel not realizing what i was reading at all.
Are you saying stack the 8 gauge at the speaker terminal? Idk if the 2 runs of 8 gauge would fit in one terminal. I'll take a pic of the sundown terminals
Those inputs look small now that I look again.
    1. Recent Topics
        • 1 comment
        • 3 views
        • 33 comments
        • 7,886 views
        • 3 comments
        • 94 views
        • 402 comments
        • 34,948 views
        • 6 comments
        • 1,763 views
        • 20 comments
        • 497 views
  • Similar Content
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
      Somewhat blown (sub still plays) Sundown X v.2 motor.
      $150 shipped!
      Basket included.
      Hello everyone, long time no see. I am selling a pair of Dual 2-ohm (technically D1.7) 12" Sundown X v.2's built by Dave Leib a.k.a "Strongman Designs."
      Reason I am selling them is because I realized upon testing to see if my digital multi-meter was working correctly that one of the coils is reading higher on the one sub indicating that too much heat had been applied to it recently so rather than risking any further damage to it I am going to assume that I have too much power for these.
      Having said this in all honesty, let me make it perfectly clear here that both subs are still in perfect working order as we speak, even the one that is reading differently. Had I not thrown my multi-meter on it to test it in order to see if it was working properly (the multi-meter itself) I would have never known there was any difference or discrepancy between the two.
      However, because one of them is reading off now and I do not know what is to be expected out of it's performance long-term I will be letting these go for $500+ shipping (that includes both).
      Any further questions or concerns please feel free to text me at 440-915-2309
      Phil
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
  • Recent YouTube Posts
