I may be buying a pretty much brand new DD m2b from a friend. I already have a Crescendo BC2000D. Would it be worth keeping the DD and selling my BC? Or just keep the BC and get the money from the DD?
whats the specs on the m2??? is it smaller in size?
You won't hear a difference in output. I'd keep what you have unless you are getting a deal on it and can sell the crescendo for more than what you paid for the DD. otherwise it's not worth it in my eyes.
  • Recently Browsing   0 members
    1. Recent Topics
        • 19 comments
        • 326 views
        • 3 comments
        • 80 views
        • 398 comments
        • 33,435 views
        • 4 comments
        • 165 views
        • 2 comments
        • 741 views
        • 5 comments
        • 1,585 views
  • Similar Content
    • By antoinez28
      I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
      Crescendo BC2000D
      Stable down to .5ohm on strong electrical.
      Up to 16.8v capable on BC2000
      Remote Bass/Gain knob with Clipping Indicator.
      Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
      2 stage copper anodized removable top plate.
      Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
      Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
      Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
      Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
      Rated Power Output(RMS)
      Clean RMS power on 13.8v standard electrical system:
      Ohm Load
      BC2000d
      1ohm
      2250
      2ohm
      1100
      4ohm
      700
      Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
      I want 550.00 for the pair or 300.00 each shipped no lower
      I'm upgrading to a bigger amp dd-m4a
    • By antoinez28
      So I'm been on the web looking at different types of 5k amps that are linkable amps, so I can upgrade my current amp set up...I'm looking for a amp out of these new or used- dd m4a, sundown audio 4500, crescendo bc5500, dc audio 5k, ampere audio 5000.1. It has to be able to do around 3800-4000 wire down to 1.3ohms.
      Running 3-18s DSS ethos box is in the works....
      Electrical is dual alts stock will run the truck, mid, and highs the singer 270amp will run only for the battery bank. 4 juice box blackcherry battery back, two runs of 1/0 wielding wire.
      ( would like more batts if space would allow)
      ( playing music daily and burbs on comps)
      I'm not looking for a father and son conversation here just wanting to know which amp would be better suited for my set up that's all thanks for reading.
    • By sps1989
      My current setup consists of:
      -Advance auto parts group 34/78 up front
      -stinger spp1500d in the back
      -mechman 270a alt
      -Crescendo bc2k
      -Crescendo c1100.4
      -Knu konceptz 1/0 all around including big 3
      I was wanting to upgrade to something bigger (maybe a dc level 6 18). I am tore between 2 options...(both options will have c1100.4 and same batteries plus some later down the line)
      1st:
      -Taramps hd5000
      -2 positive runs of sky high 2/0 from front to back
      -3 positive runs to the amp
      -Big 3 in sky high 2/0
      2nd:
      -Another bc2k strapped to the other one
      -1 run of sky high 2/0 from front to back
      -2 runs of knu 1/0 or 1 run of sky high 2/0 to each bc
      -big 3 in sky high 2/0
      I can save money going with another bc, but would the more efficient taramps be a better option? Im just curious of yalls thoughts on the taramps.
    • By DedicatedEnthusiast
      Crescendo BC3500D is approximately six months old, has never been exposed to low voltage and has no scratches, dings or dents whatsoever. Does 3,875 watts RMS at 13.8v
      Xs power XP3000 battery is sitting at over 12.7v after being out of my car for several weeks now and is rated to support 3,000 watts rms power
      2/0 welding wire is rated to support over 400 continuous amps of current and has already been heat-shrinked and fused for both positive and negative runs from front to back plus the big three upgrade and an additional trunk ground if you so wish to use it
      WIRE CAN BE HAD FOR  $120 SHIPPED FORGOT TO PUT PRICE AMONG OTHER INFO ON SALES SHEET
  • Recent YouTube Posts
