Managing my sound system...
By
Michael Simpson, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 19 comments
- 326 views
- 3 comments
- 80 views
- 398 comments
- 33,435 views
- 4 comments
- 165 views
- 2 comments
- 741 views
- 5 comments
- 1,585 views
Similar Content
By Ryann627
Thanks in advance guys.
By Aaron Clinton
We have finally released our new amp. It is a tiny tiny production run to see how people like them. Meant for the high end, SQ market, without the European price tag. If this model moves as well as I hope, it will help spawn another model in the line up soon.
https://store.soundsolutionsaudio.com/ssa-dm150-2-2-channel-amplifier-150w-x-2-ch-or-500w-x-1-ch/
Introducing the all new SSA DM150.2 amplifier. An old school approach, with updated components, for the most discerning of ears. If your front stage is lacking warmth and clarity, its time to upgrade. Our first amplifier in our high-end, sound quality, Class- A/B - Demon amplifier line. The SSA DM150.2 is the elite choice for that high end active front stage, premium passive components, and especially a sound quality sub (SSA Demon). We've incorporated direct inputs for those competition installs that use an external DSP and want their amp to be a pure gain block. Stellar looks to match the design and components. Don't let your speakers or your ears down, #levelup to the all new SSA DM150.2 amplifier.
150 Watts RMS X 2 @ 4 Ohm 500 Watts RMS X 1 @ 4 Ohm Angled Terminals for show quality installations Full Complimentary low distortion Class AB design Tiffany Style RCA connectorsFull Complimentary low distortion Class AB design Butterworth Crossover Filters for premium level performance An extra pair of input connectors for a direct input that will bypass the crossover so the amp can act as a gain block The op amps featured are TI chips w/BB technology high performance audio grade IC's Docking Pads® to reduce vibration & extend the life the amplifier DC, Short Circuit, Thermal & Overload Protection, on board fusing Diagnostic LEDs Specifications
OUTPUT POWER @ 14.4V input RMS per channel at 4 Ohms 150 W x 2 CH RMS per channel at 2 Ohms 250 W x 2 CH RMS Bridged Mono at 4 Ohms 500 W x 1 CH RMS Mono at 1 Ohm N/A INPUT SENSITIVITY 200mV - 6.0V FREQUENCY RESPONSE 10Hz - 30KHz +/- 0.5dB THD LESS THAN 0.01% S/N RATIO > 103 dB CHANNEL SEPARATION > 91 dB DAMPING FACTOR @100Hz 4 ohm > 200 CROSSOVER RANGE High Pass, 12dB/Octave 80-1.2K Hz Low Pass, 24dB/Octave 10Hz - 250Hz Subsonic N/A Variable Bass Boost (0 to +12 dB bass boost at 45 Hz) Yes Phase Shift (0 - 180 degrees) No Fusing 3 x 40A Size (L x W x H) in 16.4 x 8.9 x 2.2 -
By Aaron Clinton
I am working to expand our amplifier offerings, while staying high quality, somewhat unique, and affordable.
First up looks like a class-A/B 6 channel. No crossover network, individual gains, 150watts x 6, will keep footprint as small as possible for the design, similar appearance to the current models. Feeling out interest as it will effect the total amps I put into production.
As a side note, I am considering a 2-channel of the same line, but the demand for 2 channels right now are so low. Would not really want to build them if they are going to sit for a while.
Just curious on any input before I get production going.
By DedicatedEnthusiast
B2 Audio X2C 15
$650 shipped!
Contact at 440-915-2309 for further questions/concerns.
Recent YouTube Posts
