Recently Browsing 0 members
Recent Topics
- 19 comments
- 326 views
- 3 comments
- 80 views
- 398 comments
- 33,435 views
- 4 comments
- 165 views
- 2 comments
- 741 views
- 5 comments
- 1,585 views
Similar Content
By BigDaddy13440
Pretty much as the title implies.... I've got a 2004 Yukon XL, and I'm updating the entire system. Just replaced my alternator with a 253amp model from a 3500 series pickup (factory option! bolted right in!), will shortly be wiring up a second 1000cca battery. Dual 1/0 runs to the rear, fused at both ends. Currently only running (1) amp, and old Lightning Audio 1001.d @ 1 ohm, will be swapping that out, most likely to a Skar RP-1501.D. Two Powerbass S10-d (dual coil) subs in a 2.7-ish cu ft box built into the rear quarter panel. Tuning is way too low, probably about 24-25Hz. Factory speakers in the doors and rear pillars, will soon be changing them out - probably doing a pair of 6.5's in the front doors, a single 6.5 in the rear doors, and a pair of 10" Powerbass S-10's (single coil) sealed in the front portion of my center console as mid-bass, from 60-150Hz. Will plan on running the speakers and front S-10's on a five-channel amp, most likely Skar's AP-600.5.
I've got nothing set in stone for the 6.5's, there are literally hundreds of options - but if anyone has some reasonably priced option, please offer suggestions. My biggest dilemma is figuring out what to put in the rear C-pillars. The factory fill is a 2" or 2 1/2", only about 3/4" deep. I'd like to go bigger, even if it's a 3 1/2" or 4". Would run them in parallel with the rear door speakers, dropping the load down to 2 ohms, the same as the front doors. Has anyone ever seen the C-pillars upgraded/enlarged? I found a pair of PPI Sedona series 4" two-ways, supposedly will handle 60 watts RMS, max of 200 watts. The Skar 5-channel is rated at 90x4 @ 2 ohms, so each would see a safe 45 watts.
Thoughts/suggestions?
By Tirefryr
Selling off everything but a few things. All items are BNIB unless otherwise noted. I am NOT interested in trades, sorry.
SOLD!
By altoncustomtech
Okay, this little build will be going into my 1992 Oldsmobile 88. I bought the car about 7 years ago right after I started working for the pipeline I'm working for now. I got a hell of a deal on it and got it so that I had a car just for driving to work so my wife would still have the van to drive at home. I only drove the car for a couple of years before I bought the Jimmy and right after that I gave the Olds to my mother and father in law to drive because their car broke down and my mother in law was having to run around to doctors and things for her cancer treatments and such. Well fast forward from then and I find myself with the Jimmy out of commission and my father in law wasn't driving the Olds anymore because he had gotten his own car. So he gave the car back to me so I could have something to drive to work again.
Just before I gave the car to him to drive I had dropped an OLD Pioneer CD player I had bought used on Ebay for $20 to put in the car because the factory radio didn't work. I also put a pair of Hifonics Zeus Components I had lying around from another project in the rear deck in place of the bad factory 6x9's. It still sucked but it made music. Now after driving the car awhile again I've gotten fed up with the damned thing. Only one of the mids in the Zeus components are working anymore and the front factory tweeter/mid thing in the front doors are shot. So I've picked up a little bit of stuff I got for cheap and I'm hopefully going to get it sounding better than it is right now. I'm also going to use this little build as an experiment as well on some ideas I have floating around in my head.
The equipment going in:
Pioneer DEH-X7500HD - Used a discount I had on hand at SonicElectronix to get it for under $80
Aura 4x6 coax's - On clearance at PE. I don't normally mess with oval speakers and such but for their clearance price I wanted to try them out. Going in the front doors.
Dayton SD215A-88 - Used a promo code here and got them for $19 each. Going to use the pair as dedicated midbasses in the rear deck.
JBL GTO1004 - Already have it on hand, will use it's internal crossovers to run the Aura's up out of harms way and utilize the Dayton's in the midbass range.
We'll see how it turns out. It should be a fairly quick and easy build. The goal is simply to get something that sounds reasonably good with better overall response than it has now and able to get more volume out of it than it can produce now, especially without the front speakers sounding like they're going to puke on every drum hit even at low listening levels.
Recent YouTube Posts
