Recently Browsing 0 members
Recent Topics
- 20 comments
- 409 views
- 400 comments
- 34,328 views
- 3 comments
- 132 views
- 4 comments
- 247 views
- 2 comments
- 786 views
- 5 comments
- 1,646 views
Similar Content
By jcarter1885
By Joshdashef
Hello and welcome to my daily headaches! I'll start this build log off with my past setup, my current, and finally update throughout December as I work on probably the furthest this little Civic will let me go.
My instagram: https://www.instagram.com/joshdashef1/
The Past Build:
Head unit: Pioneer 80 PRS
Mono Amp: Rockford Fosgate Prime 750.1
Subwoofers: Rockford Fosgate P3D4 12" (two)
Kicker 4 gauge amp kit OFC
Stock Electrical (alternator included)
Did do the big three sometime between here and current build
Prefab Box: Q-Power Box (Dual 12s)
Tips: Tesa taping RCA's, Marking RCA's Low/Mid/High or similar,
Big Three with loom. Wire was Sky High 1/0 OFC with some 1/2" loom I believe. Old military style terminals (DO NOT USE THESE) they cracked my battery eventually.
By mikebingham34
Hello all, I have been away from the forums for some time since graduating college and started working again. Now that I have some money to finally move away from these seemingly low powered setups (6 systems since 2012), I am looking for help with my wall build. I am going to be building the base to the wall in my 2016 Ford Focus sedan in a week or two, and there is a lot of room to work with (over 30 cubes). I will be running 2 18" ZCONs on (undecided) either a 5.5k or 6.5k amp with supporting electrical (batt bank, lots of OFC wire, and HO alt). This is my daily, and I just want a ground pounder with no care to what numbers it'll put up in the lanes. I would like to demo a lot. I'm thinking 8 cubes per sub (16 cubes net) tuned to 32 Hz is a good place to start (recommended by SSA). I'm thinking either a center slot port, or a top port.
** I listen to ALL kinds of music, Decaf/DJSNT, rap, hip hop, metal, rock, 80s/90s pop, jazz, country, movie scores, blues, dubstep/electronic, classic rock, oldies, etc, etc..**
Now... my questions are: How much port area do y'all recommend? Is 8 cubes of net volume per sub a good amount? Should I be alright running an underrated 5500 watt amp, or go with the 6500? What port orientation shall I go with?
If I think of more questions, I will be sure to post them.
P.S. Sorry if I am asking some questions that are common knowledge among these builds, but this is my first "loud" and "high powered" setup. My two loudest systems thus far have been a single Obsidian Audio 15 on about 900 watts, and 2 Sundown Ev3-12's on 1300 watts.
Thank you for your time and patients everyone! Cheers.
Recent YouTube Posts
