Passive Radiator tuning calculation
By
SpeakerBoy, in SPL & SQ / Fabrication
Recently Browsing 0 members
Recent Topics
- 400 comments
- 34,224 views
- 19 comments
- 390 views
- 3 comments
- 113 views
- 4 comments
- 223 views
- 2 comments
- 767 views
- 5 comments
- 1,621 views
Similar Content
By slim142
Not sure how many people here know what these are used for or what they are, but I thought I would still post it just in case anybody sees anything they might be interested on.
These are from a project that I had to cancel because I started college a few years ago and money became insufficient to finish it up.
All prices include shipping CONUS. Paypal only please. No international shipping.
Let me know if you have any question. I also take offers if you buy more than one item.
heatware: slim142
eBay ID: presler142
TFC Xchanger 480 Quad Radiator NIB - $95
TFC 120mm Fan Shrouds NIB - $60 for all 4 (each includes red, blue & green LEDS!)
Pentek In-Line Water Filter NIB - $20
Laing D5 Vario/Swiftech MCP655 Inline 12V DC Pump (with variable speed knob) + Detroit Thermo D5 Top + Bitspower 655 Mod Kit - $110 (all together)
EK Reservoir RES250 Rev. 2 Multi-Opton Reservoir + Anti-Cyclone + Case Holders - $45 (all together)
Alphacool Valve + 2 Bitspower Extension fittings + Bitspower Cover fitting + Bitspower Multi-way (3-way) fitting + Syringe + Silver KillCoils by iandh - $25 (all together)
Sunbeam PSU Modding Tool Kit + Some black heat shrink and cable sleeving + 4 120mm Black Fan Grills + 1 120mm Silver Fan Grill + 3 140mm Silver Fan Grills - $15
Swiftech Steel MCB-120 Radbox Rev. 1 Black - $15
HP Expresscard Analog TV Tuner Card - $15
Two D-Tek GFX UNI-Sink (8800Gt/GTS G92) - $25 (for both)
Two D-Tek FuZion GFX 2 GPU Water Blocks - $50 (for both)
Bitspower BlackFreezer Striker II Extreme 790i Chipset Water Block - $45
Here is my Woot! screaming monkeys collection. Well taken care of, they have never been played with, thrown/fly/scream.
Get the 3 giant monkeys (still in their plastic bags) for $50
or any 5 regular for $20
or get all 24 of them for $90
By Omega_Ace
If you have two boxes at the same volume and say one had a 2" slot port width and the other had a 3.5" port width tuned to the same frequency would there be a difference? Would the 3.5" port allow you to feel the lows better than the 2" port but sound the same since they are tuned the same?
By bassthrashin
I would like some input on building an enclosure for 2 ZCON 15D2's. The max cubes available for the box is 7(3.5 per sub) after displacements. I want to tune at 31hz. I have seen the recommendations SSA's site for enclosures but would like to have some outside information on how well these will do in 7 cubes . They will be running off a SAZ3500 at .5ohms. Thanks.
By 10rogerd
Hello all, I'm new to this forum, but not to car audio. I am however new to the Sundown woofers. I'm hoping you all can lend some help and thank you in advance on my enclosure design. What I have is an 05 Acura TL I'm doin a pair of Sundown SA12s in the trunk. Subs to be fired foward and a 6in Aero either out the back or side. I have tried several enclosures with foward fired subs & port, but the car just did not really like it. Last setup was a single CV Stroker12, power was supplied by an O.S. USamps VLX400 1ohm mono. I had good results with two 4in PVC ports fired back, Sub obviously foward. Then tried a 6in Aero out the drivers side of box. The Aero was slightly better. Anyway, my questions are... I have roughly 31in wide/26in deep and 13.5in tall to work with. I have an enclosure drawn up already with a net volume of 4.05 ft>3 and Torres is telling me with the 6in Aero @ 17in long this will yield me a tune of 29.64htz. Does this sound rite? I do want it to play very low!! I Only play music. Rap/Hip Hop/R&B/Funk/lil bit of rock/metal. My other concern is how will these subs like this size enclosure with the brutal power of the VLX? Amp is "rated" @ 2400 wrms @12.5v. Charging system is decent with a total of 4 large batteries and a 50farad Stinger Cap. All power/ground wire is 1/0 Monster Cable. Voltage playing it hard stays in the mid to high 13 volt range. Any input on if this will work fine would be great! Thanks again everyone.
Recent YouTube Posts
