Fi BTL
Fi BTL amplifire
Ok i need some help on picking out the amp for my Fi BTL fully loaded i have to amp choices tell me wich one you think is better or if neither of them ar good
Amp 1.
XT4000DE V2 1,500 watt RMS (4000w peak) mono car amplifier
Class "D" fully digital power supply
4000 watts peak output
1,500w x 1 RMS @ 1 ohms
800w x 1 RMS @ 2 ohms
500w x 1 RMS @ 4 ohms
Bridgeable
Efficiency: 86 % @ 4 Ohms or 84 % @ 2 Ohms or 76 % @ 1 ohm
Fully adjustable butterworth low pass crossover filter
Low Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octave
Adjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZ
Subsonic Filter: 15-40 HZ @ 24 dB per octave
Low level Input
RCA Pre-amp output
Pass through output for multiple amp installs
Block Power Connector
Requires true 0 gauge power wire for installation
Screw terminal barrier strip speaker connectors
8 - 18 AWG speaker connector gauge
Aluminum heatsink
Convention cooling
power and protection LED Indicators
Class D
Frequency Response: 20 HZ - 500 HZ
Weight: 13 pounds
Dimensions: 1.875" x 10" x 15.75"
» Product Specifications
CEA Compliant No
Channels Mono (1 channel)
Class Class D
Condition BRAND NEW IN ORIGINAL PACKAGING
Continuous Power at 1ohm (Mono) 1301- Up
Continuous Power at 2ohm (Mono) 601-800
Continuous Power at 4ohm (Mono) 451-600
Fan Cooled Yes
Fuse Rating N/A
Manufacturer US AMPS
Max Input Gauge Size 0
Minimum Impedence 1 ohm
Peak Power 3001- Up
Remote Bass Knob Yes
THD at Rated RMS <1%
Warranty 1 YEAR
Amp 2.
5000 Watts Digital Mono Block Amplifier
1 Ohm Stable
Max Output Power: 5000 WATTS @ 1 OHM
1900 watts RMS @ 1 Ohm
1600 watts RMS @ 2 Ohm
1400 watts RMS @ 4 Ohm
High Current Amp
More Efficiency than other Class D Amp Designs
Class D Digital, Monoblock
Built in low pass crossover filter
Crossover Slope 24DB per Octave
Input Sensitivity Control (6V to 0.2V)
Bass Equalizer Control (0 - 18 dB)
Bass Frequency Control
Phase Control (0 - 18 0degrees)
Subsonic filter
Bass EQ frequency : 40 HZ - 120 Hz
Bass Boost - 0 - 18 dB
Wired Bass Remote Control
Gold Plated Terminals & RCA
0 Gauge Power terminal
High Efficiency Low Heat Emission
High Damping Factor For Improved Bass hits
Uses Less Energy from the car battery, so your lights don't need to dim, and you can still have a lot of power!
Real 1-Ohm stability means this amp will stay cool, after pounding for days straight, with 2 dual voice coil 4 ohm subs running down to 1 ohm. Other amps may say 1 ohm stable, but this one is truly 1 ohm stable!
Includes free fuse holder + bass knob
Thanks For The Help
Seriously?
If it is important to you, take your time and give more info.
I am not looking that shit up just to take a guess because you are lazy,
Yeah, what kind of amps are they? You have a 1500 watt and a 5000 watt up there, maybe you should look at something in the middle. I've got a RF T1500-1bd for my BTL 18. I might end up getting a T2500 in the future, but I think the 1500 should do fine.
The XT4000 is a Us amps. Xterminator series. It even says it in the post :)
We need to know what the other amp is, specifically. Not just the power ratings.
careful here its a 1500 rms amp and a 1900rms amp but idk what quality brand it is so :suicide-santa:
Seriously, any company nowadays who still list power ratings by peak power... i'd skip that choice.
theese are the ampss
http://www.audiosavings.com/products/Mono-Car-Ampl
ifier/PERFORMANCE-TEKNIQUE-5000w-MONO-POWER-AMPLIFIER-C
AR-AMP/ICBMSUPER.aspx
ifier/NEW-US-AMPS-XT4000DE-V2-4000-WATT-MONO-CAR-AMPLIF
IER/XT4000DE+V2.aspx
If you got any ideas for amps send me the links
Amp 1. http://www.audiosavings.com/products/Mono-Car-Ampl
Bridgeable
Low level Input
RCA Pre-amp output
Aluminum heatsink
Convention cooling
Class D
Weight: 13 pounds
CEA Compliant No
Class Class D
Fan Cooled Yes
Fuse Rating N/A
Peak Power 3001- Up
Warranty 1 YEAR
Amp 2. http://www.audiosavings.com/products/Mono-Car-Ampl
1 Ohm Stable
High Current Amp
Subsonic filter
Thanks For The Help
do not get performance teknique some guy fried his BTL with clipped power go with a USAMPS MD-2d or sundown saz 1500
That had nothing to do with the amp more so user error, I wouldnt get one of those amps but that is not the reason why.
That's not the amps fault. ;) (user error)
I would take the first one, but i think the best choice would be the AQ.
(by the way, you're links don't work.)
EDIT:Jay-cee ninja'd me .... :peepwall:
Edited by kirill007
Rockford Fosgate FTW! I got my T1500-1bd from ebay for $395 shipped brand new.
