best amp for the money?
By
TreezNSteez, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 400 comments
- 34,224 views
- 19 comments
- 390 views
- 3 comments
- 113 views
- 4 comments
- 223 views
- 2 comments
- 767 views
- 5 comments
- 1,621 views
Similar Content
By Wolfram Audio
Now available on the SSA store!
I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
Wolfram Audio W-3000.1:
RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) : 6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-1500.1:
RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-600.1:
RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
Wolfram Audio W-125.4:
RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
By Godsmack
- 27 Raptor 1/0 AWG Ring Terminals $20
- Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
- 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
- 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
- 50ft 16AWG speaker cable spool $5
- Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
- Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
- 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
- Approx 400 ft 16AWG Q power speaker wire on spool $40
- Stinger 150 amp circuit breaker $25
- 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
- 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
Rockford Fosgate 2 output top mount battery terminal $10
- Rockford Fosgate RCA coupler $5
- Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
- Rockford Fosgate pack of 2 100amp MAXI fuses $10
- Knu Konceptz Negative top mount terminal $10 -
Metra Honda Harness [BB-WHHDI] $10 -
Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
- Pair of Dynex square box terminal cups $2
- Dynex OEM Ford Radio removal tools $8
- Stinger Blue HPM voltage meter [SVMB] $15
- Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
- Generic ANL fuse holder, no cover $5 -
Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
- 16 ft Monster RCA cable $20 -
Stinger 1/0 AWG ring terminal $4 -
2 2male 1female RCA adapter $5 each or both for $7.50
- 1 RCA to RCA dual male wire 9" $2 -
2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
Total price when purchased individually: $761 Buy the whole lot: $650
Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
- Viper 500.4, missing xo cover, and right mounting feet. $300
- MTX Road Thunder XO's for componants. $20 for the pair
- Eclipse SC-8355/8365 XO's for componants $50 for the paid
- Phoenix Gold Octane 4.0 2 amp. $150
- JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
- Digital Designs DD C1. $140
ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
By matj1990
So looking for some info about amplifier and efficiency.
I have a xcon dual 1ohm 10" so i can run at either .5ohm or 2ohm What i would like to know is 1500w @ .5ohm or 1500w @ 2ohm the 2ohm amplifier would be drawing more power to make its wattage because of the higher resistance correct ?
By GarrettHarvey
Getting two hds212s and wanna know what amp to get(sq brand) , and if i should get dual 2 ohm or dual 4 ohm. And if youve done this build, what are the box measures
Recent YouTube Posts
