Mark LaFountain
Welcome to the IHoP v.2
Sean I figured you were fucking with me, but just had to be sure.
Jared- I'm hunting around, just trying to do homework first
J
Made Chili today in the slow cooker. Heats up more than the Broncos did,
J
Try adding the Desired Volumes and see what happens.
Tried all kinds of different shit.
Here's the link if it loads.
http://www.mediafire.com/download/tvha8603c9n8d9n/TorresBTC.zip
Otherwise the link is in Torres's signature . here's the tutorial.
http://www.stevemeadedesigns.com/board/topic/38791-torres-box-tuning-calculator-updated-818/
Try uninstalling and re-installing, sometime's that works. I generally download them on my work computer as with most exe file's. I uninstall any programs I'm not using regularly as soon as I am done with them. Hope this help's.
Tried it all.
As soon as I input some numbers for the outer dimensions the gross volume gets stuck at a round number ( 1, 2, 3 cub feet etc.).
J
 That's a good call. I started with the Blu the day before I went to Hawaii. I had been cold turkey for almost a month but was being a uptight prick so needed some sort of nicotine and that was the W's suggestion. Mark quit using the Blu last year, which if you remember he was a pretty heavy lemaC smoker. Long story short, I thought the blu sucked as it taste's like meth, and the battery's don't last. I literally would suck until I was blu in the face (pun intended).
 When I got back I tried Ivy's CE4 tank with a 650 mAh eGo battery and realized how well it worked as a nicotine delivery system and without turning blu in the face. I then remembered I had the eGo starter kit someone had given me. I dug it out and bought the CE4 (2.4ohm) tank at Smoker friendly as my girls store was closed that day. The CE4 was good other than the tank buckling and leaking IF carried in your jeans pocket, and the easy to lose o-ring. After losing the o-ring on the CE4 I remembered I had an H2 (1.8ohm with wick mod) tank and 950 mAh battery my girl had given me the last time I tatt'ed on her. Instantly was happier with the bigger hits from the 1.8 coil. Also the H2 is a cleaner, simpler design with less parts to fuck up. Bought the H2 for Ivy to replace her CE4 and she agreed it was a better budget tank.
 I also would question anyone I was working on that had a vape pen. As everyone had a different setup I quickly figured out the two most common battery style setups. The one's Seth talks about are AA size'ish and require a seperate charger like one for AA's. This type requires a head unit to hook the battery case to the tank and serve as the controller. These battery setups require a different battery case for each size mAh battery. The other most common battery is the eGo style ones. These are one piece and screw on to a usb cord for charging. The controller is built in to the eGo battery. I upgraded to the Protank and eGo-C Twist once i had a little time in and knew what I was looking for. Believe me it doesn't hurt to have extra's for backups so even if you start with a basic setup and upgrade once your a little more familiar, the money spent won't be in vein. Or if your like me I just give them to others wanting to start vaping.
 If you are just using it as a nicotine delivery system to quit smoking then I suggest get the eGo-C Twist and either the H2 or Protank. The usb cords are like 2 dollars so grab a couple of those too. They did just come out with a slim Protank but the mouth piece has a o-ring push style connection opposed to the
threaded on most tanks.
 See if there is a local vape store to go try things out. Don't let them sell you a kit if it has bullshit you don't need as you can usually piece a setup together for less.
Tried it all.
That's an odd one as I don't believe there is a particular sequence to entering the value's like WinISD. What other calculators do you use?
Fucking spammers. I would deal with that shit IF I was a mod or tech.
Tried it all.
I use Windows Calculator and this site for the port:
http://www.carstereo.com/help2/Articles.cfm?id=31
