Welcome to SSA Car Audio Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
sundownz
Re-Cone Prices
31 posts in this topic
To order a re-cone e-mail bryan@sundownaudio.com -- do not e-mail my "sundownz" address if you need a quick response.To reduce back-and-forth e-mails ALWAYS include the following :
1) What you are ordering -- Model, Coil Configuration, Etc.
2) If you already have a basket or not; please check below for any special notes.
3) If you need ANY custom options please specify up front.
4) !!! YOUR ADDRESS AND NAME !!!
5) A picture of what you have goes a long way to be SURE we are talking about the same thing.
IT WILL TAKE, ON AVERAGE, 10-14 days for a built item like a drop-in to be completed.
EDIT 8/30/11 : WE CANNOT WARRANTY DIY RE-CONE ASSEMBLY ISSUES. Read and understand this -- if you are not 110% sure about re-coning the driver ask us or send it in. We can ONLY stand behind labor that we perform. Manufacturing defects in the kit itself are of course our responsibility but installation is 100% the customer responsibility. This includes ticking, broken parts, etc. Thanks for the understanding.
This thread over-rides any prior quotes or costs -- I sat down and really calculated the numbers this morning and costs may have varied in the past on estimates.
These prices are the same for everyone; Team, dealer, customer, etc.
All costs + SH charges.
KITS DO NOT include shims or glue. White paper trimmed / stacked to spec works perfectly for shimming -- use enough where it is snug but not so tight you can barely get the coil in the gap.
For glue we suggest Loc-Tite 5-minute epoxy with mixing tubes to glue the spider to the frame (MAKE SURE to sand it first) and we suggest Amazing Goop or E6000 for the surround and dust cap (sand frame for surround and rough up the glue surface of the dust cap with sand paper as well). These can be purchased from Lowes or Home Depot very commonly and some Wal-Mart and Craft Stores. We can sell CA glue by request but it typically is not very cost effective for the end user.
MODEL -- RE-CONE Price -- FRAME Price
E8 v.2 (or v.1) -- $28.00 -- $5.00
* D2 / D4 available Stock
* MUST buy basket to re-cone a v.1 model
E8 v.3 -- $30.00 -- $5.00
* D2 / D4 Available
E-10 -- $35 -- $10
E-12 -- $35 -- $10
E-15 -- $45 -- $10
* D2 / D4 Available
!!!FOR SA-8 KITS SEE THIS THREAD TO DETERMINE WHAT MODEL YOU HAVE. WE MUST HAVE THIS INFO TO MAKE THE CORRECT KIT!!!
SA-8 v.1 or v1.5 -- $32.00 -- $10.00
* MUST SPECIFY v.1 or v1.5 when ordering !!!
* CCAW 4-layer D2 or D4 SPL Coils Available No Extra Charge (these are lighter but can still be used daily as the gap is not tighter than stock)
* These kits now ship standard with a round lead wire that is more rugged
SA-8 v.2 -- $50.00 -- $15.00
* SA-8 v.2 Kits Available with SPL 8-layer D1 Coil for $20.00 Extra (Very tight gap and may tick slightly at high excursion)
* Extra Spiders Available for $5.00 Extra Each for a MAX of FIVE (stock is two); DO NOT order extra spiders for anything but SPL
SD-2 8 -- $40.00 -- $15.00
* D4 Coils ONLY
SD-2 10 -- $35.00 -- $15.00
SD-2 12 -- $35.00 -- $18.00
* D2 / D4 available
SA-10 -- $40.00 -- $15.00
SA-12 -- $40.00 -- $18.00
SA-15 -- $50.00 -- $21.00
* SA-10/12/15 add $20.00 for SPL Coils (D1,D2,D4)
* D2 / D4 available in stock opper
NSv1 12 -- $100.00 -- $25.00
NSv1 15 -- $110.00 -- $30.00
NSv1 18 -- $120.00 -- $40.00
* 3H Nightshade Spiders Stock
* Add $10.00 for double leads
* Z v.3 Spider Available No Extra Charge
* NS v.3 Spider Pack Add $10
* D1 / D2 Available
NSv2 12 -- $130.00 -- $25.00
NSv2 15 -- $140.00 -- $30.00
NSv2 18 -- $150.00 -- $40.00
* D1 / D2 Available (SPL COIL Available)
Zv2 12 -- $100.00 -- $25.00
Zv2 15 -- $110.00 -- $30.00
Zv2 18 -- $120.00 -- $40.00
* Copper or Aluminum Coils Available
* Z v.3 Spider Pack Now Standard (5/1/12)
* MUST USE Z v.3 SPACER
* Add $10 for NS v.3 Spider Pack
* D1 / D2 Available
Z v.3 10" -- $115.00 -- $20.00
Z v.3 12" -- $115.00 -- $25.00
Z v.3 15" -- $125.00 -- $30.00
Z v.3 18" -- $135.00 -- $40.00
* Add $10 for NS v.3 Spider Pack or "Traditional" 3H NS Pack
* The 10/12 models use a different coil than the 15/18 models
* The SPL coil can ONLY be used on the 10/12 with the "Traditional" 3H NS Pack
!!!! IMPORTANT NOTE : YOU MUST USE OUR NEWEST 12-spoke 15" FRAMES TO USE THE Z v.3 OR NS v.3 SPIDER PACKS !!!! They are 8 3/8" spiders and require a modified top landing. The other spiders for 10/12 and the 18 are compatible with any 12-spoke / 6-spoke that I am aware of.
Also -- the NS cone will NOT be offered on ANY drivers with a v.3 style spider pack in 15s or 18s. The v.3 spiders (Z v.3 and NS v.3) can exceed the mechanical limits of the NS style cones in these sizes.
NEW PLATFORM PRODUCTS (Basket Prices are WITH the purchase of a SUNDOWN product re-cone) :
X-10 -- $130.00 -- $70.00
X-12 -- $135.00 -- $80.00
X-15 -- $140.00 -- $95.00
X-18 -- $155.00 -- $40.00
* 18" Use the Standard 6-Spoke Frame w/ a 257mm Spider Adapter
* D2 and D4 Coils Available (CCAW Round Wire)
* Add $10.00 for Z v.4 Stiffness Spider
* Add $20.00 for NS v.3 Stiffness Spider
Z v.4 10 -- $150.00 -- $70.00
Z v.4 12 -- $155.00 -- $80.00
Z v.4 15 -- $160.00 -- $95.00
Z v.4 18 -- $175.00 -- $40.00
* D1 and D2 Coils Available
* Softer X Spider Available - NO EXTRA CHARGE
* Add $10.00 for NS v.3 Stiffness Spider
NS v.3 10 -- TBA
NS v.3 12 -- TBA
NS v.3 15 -- TBA
NS v.3 18 -- TBA
* -- Both the X and Z v.4 kits / Frames can be retrofit into the NS v.1, NS v.2, and Z v.3 motors; these motors cannot handle the FULL capacity of the new soft parts so a hard bottom is possible.
** -- SPL kits are in development with a different cone and spider type. Pricing is TBA on those.
*** -- The Z v.2 motor bolt pattern is compatible with the new platforms as well but we do not suggest it as it has a limited amount of rearward travel (41mm).
Baskets WITHOUT a Re-Cone Kit (With Gasket and Terminals) :
10" -- $90
12" -- $100
15" -- $115
+ SH
* The new baskets are BOLT PATTERN compatible with any of our 3" coil motors to-date. They use the standard 127mm pattern so can be used on MANY other products.
Edited by sundownz
1
Well done, no more confusion or questions!
0
cool might have to get the dual 1's for my sa's
0
awesome.....i was just wondering what it would cost and if i even could recone my SA-12s in the event i hurt one or both......
0
Well done, been wondering about this myself. Can I recone a Z15 v1 with these new v2/v3 parts?
0
The can be built with an NS v.1 coil and several different spiders.
0
ok i got to ask since i really want to use these. how much for a SD-1v1 12" recone and if possible with a 10" frame :D
0
^^^^x2!!! I have a SD-1v1 10 that needs a recone. :peepwall:
0
On the SD-1 line I will have to see what I can do -- the frames cannot be changed on SD-1 v.1, though.
Most of the parts for these were all American made and many of the factories no longer exist but the build house MAY have parts. For serious SD-1 inquiries e-mail me -- they will be more expensive than SA re-cones, I know that for sure.
0
I know i emailed you earlier this month about the E8 v.1s, wondering if i could send them in even if you dont have the parts.
0
i ordered one :D i wanted to see a about parts for E8's V1's aswell.
0
Just to make sure I'm looking at it right, if I want to get an sa10 reconed to an sa12 it would be 58 + shipping? And would you be able to estimate shipping to 85741 if possible?
Thanks a lot -Rick
Edited by ricksi30
0
....Gonna Need Alot Of E8 Recones.... :peepwall:
0
Thanks a lot -Rick
Yes, if you want a quote email me.
0
We haven't re-coned any E8 v.2s yet.
Have alot of inquiries on v.1 re-cones but I need the adapter made for the frame which I haven't had time yet.
0
I get alot of e-mails about this so I am posting it up in one place. I revised the SA re-cone costs a bit as well for reference.
MODEL -- RE-CONE -- FRAME
E8 v.2 -- $28.00 -- $5.00
SA-8 -- $32.00 -- $10.00
* D2 / D4 available in stock coils in above
NSv1 10 -- $100.00 -- $22.00 ***
NSv2 10 -- $130.00 -- $22.00 ***
Zv2 10 -- $100.00 -- $22.00 ***
* 2H Z v.2 Spiders Stock
* Add $15.00 for Nightshade Spiders
18" available by request with Z v.3 spiders
12" available by request with Z v.3 spiders
*** -- I will only make 10s with the Z v.3 spider pack unless expressly used for SPL burps only.
15" not yet available with Z v.3 spiders... due in the summer. Need a slightly varied 12-spoke for this spider so will not work with old / current frames we have in stock.
0
Crystal CMPx215...can you recone it for me?
Thanks!
0
Thanks!
I do not know - have never had one on hand.
0
Hey can you use sa parts to recone a skar vvx12? I know you designed it and it is a lot like the sa so figured you could use the same parts. Except I want to recone it to a 15.
0
so i just got done looking at the reconed ufo btls thread u did annd got kinda excited cuz i didnt know u did custom recones. i've got a rockford power series hx2 15 with a blown coil. its a d2 ohm 4" coil rated at 1000wrms 2000wmax. i ran the sub on a 500wrms bazooka amp for about 3 months until i got my saz1500. within 3-4 days i was to gain happy i guess and got it to hot, dustcap was literally to hot to touch. it just melted a section of the coil about 1/4" long other then that one spot the entire coil is still bright n shiny.
think u could hook sumthing up on this thing? i cant find recones for this thing anymore and trust your work alot more the getting a psi recone. i would like a coil i wont damage easily with the saz1500 if we could make this work
i would've emailed u but couldnt find your email address and couldnt remember it. hit me back here or email me at aimoneson@yahoo.com
0
Wow I didnt think frames would be so cheap, awesome.
I was told I dont know what i am doing cuz of my pile of cones.... must be a lot of morons that buy sundown on this forum :-O
jk jk, jus makin a point is aLL
0
My bad, just remembered that was on carstereoforum.net my bad!
0
Usually I cannot do Rockford stuff.
0
  • Recently Browsing
