francher
Help w New sound system
Hello everyone, I have exactly 2k to spend on a new system. I'm not sure what to buy exactly, I'm looking for good speakers(x4), a single 15 with an enclosure and an amp that can hold all of that. What would you guys prefer?
.........................................................................you included no details at all? explain a little better.
I can't explain something I don't know, I'm just wondering what I should buy with the 2k. I want big bass but clear enough to hear the music
How much room do you have? What music do you listen to? What electrical upgrades do you have? Is this for just everyday?
Don't worry about the rear speakers. Just focus on the front speakers.
You can do a lot with $2k, so much so that you might not even need that much for your goals. We do need much more information as listed above. If I were to maximize your budget though, this is what I would do.
$2000
Big 3 Upgrade -  ~$40
Image Dynamics CXS62+Amp - $300
2 SSA GCON 12s - $500
Crescendo 2000D - $500
2 Wiring Kits - $100
Head Unit - ~$150-$300
Enclosure - $200 (Built by someone else... $60 or so if done yourself)
This is with brand new, quality equipment.
$2000
the big 3 will support that? no.
Edited by eggyhustles
Dont worry about buying 2 sets of speakers, Ditch the rear speakers and spend more money on your front set.
More info !
What type of system, daily driving or to compete?
What type of vehicle do you have?
what is the amp rating of your vehicle's alternator?
How much space are you willing to give up, height, width and depth?
What equipment are you running now or is it all stock?
More, questions may be asked later, but these are all good for a start.
Welcome to SSA.
this would be like an everyday use, I seriously don't know other info. This is all brand new
More info !
answer these!
I pity you if you actually can't answer those other questions without someone holding your hand.
You're question is a bit like saying: "I want to buy a car for $30k. Which one should I buy?"
$2000
these posts are terrible. without understanding his goals you cannot possibly begin to make suggestion. you're just looking for the quickest way to waste his money..
I don't even have a car yet this is why I can't answer obviously? I just wanted opinions?
my opinion is that you can't design a system without understanding the environment in going in.
$2000
What you consider to be a waste of money might not be a waste to him or to others.
OP asked for big bass while being able to hear the music, I'm assuming those are his goals.
OP gave a budget, he asked for opinions, I gave him mine.
Worry about getting a car before you worry about a system.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 90 views
        • 5 comments
        • 89 views
        • 3 comments
        • 23 views
        • 1 comment
        • 13 views
        • 67 comments
        • 1,610 views
        • 7 comments
        • 220 views
  • Similar Content
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
      Somewhat blown (sub still plays) Sundown X v.2 motor.
      $150 shipped!
      Basket included.
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email colin@wolframaudio.com
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
      Hello everyone, long time no see. I am selling a pair of Dual 2-ohm (technically D1.7) 12" Sundown X v.2's built by Dave Leib a.k.a "Strongman Designs."
      Reason I am selling them is because I realized upon testing to see if my digital multi-meter was working correctly that one of the coils is reading higher on the one sub indicating that too much heat had been applied to it recently so rather than risking any further damage to it I am going to assume that I have too much power for these.
      Having said this in all honesty, let me make it perfectly clear here that both subs are still in perfect working order as we speak, even the one that is reading differently. Had I not thrown my multi-meter on it to test it in order to see if it was working properly (the multi-meter itself) I would have never known there was any difference or discrepancy between the two.
      However, because one of them is reading off now and I do not know what is to be expected out of it's performance long-term I will be letting these go for $500+ shipping (that includes both).
      Any further questions or concerns please feel free to text me at 440-915-2309
      Phil
  • Recent YouTube Posts
