MKader17
Deadening the Z
Here goes to the start of deadening my 02 Z71. Lots of deadening going in.
155 Sq ft. Raammat
5 or 6 Yards Ensolite
5 gallons and 1 quart of Spectrum
GM's way of trying to stop you from removing the rear bolts on the front seats an 11mm 12 point did the trick. Also the front nuts on the front seat are removable with 15mm 12 point.
Carpet is not so clean lol
When I saw this clip for the first time I thought "I'll come at you like a spider monkey!"
The rear light needs to be removed before dropping the headliner to disconnect the light
More pics to come
man compare to FJ your floors are really flat, looks like it will fairly easy to get it done up. Do twice what you are thinking on the roof, and go up as high on the fire wall as you can get....
I put in 240 sq. ft. of damplifier pro, 36 sq. ft. of overkill pro, a gallon of spectrum, 6 sheets of luxury liner, 3 cans of spray foam, and a whole bunch of insulation....
my sound deadener install part 1
this was a few extras I did later, kind of a long read
part 2.
this is what I did last week.
part 3, with some new equipment to go with it....
Edited by fjcruisin
^x2
and
:woot:
This is motivating me to do the roof in the jeep :)
UpDaTe!!!
What I started with this morn (Thanks TMAX for doing this)
Not much to see, but this is the door I did
My friend did the whole back wall and some of the floor (there is much more of the floor done now, just didn't take a pic yet)
Got quite a bit done today, but I will not be done by the end of this week. I just know. So I am trying my hardest to finish the floor so I can get carpet and seats back in and I will be able to work on the Headliner and such during the week.
Gotta a Question for you Silverado owners. How do you get the plastic at the front of the floor out (looks like a form of stock deadening. I want to get under there with mat)
Even with 2 extra hands available for help you still moved slow :P
Distractions...distractions... :lol:
Can't blame a man for swooning over the perfect woman can you?
Finally an update!
This is how I drove my truck all last week...
Now for progress...
Goodbye rear fill forever!
And Goodbye rear cab vent! Got rid of the passenger side one but left the driverside one
My Friend Trey putting a second layer over the rear cab vent
Nice so far! I have 100sqft of Fatmat I am putting on the floors and the trunk floor, then 40sqft of damplifer going in the trunk around the wells, back part by the lights, lid and rear deck. What I have left over will be doing the front doors. In due time will be doing the back doors and headliner and then get some overkill to put on most of it.
Your install makes me look foward too it..........................................NOT!
an update?????? what????? oh yeah
Last time you saw the front doors....
Add some spec!
Let it dry :P
Fiberglass panels coated in spec
Add them together!
and seal the edges!
First layer on the rear door
Second
The other side all nice and dry
Spectrum and Ensolite on the door panels!
I also have a layer or ensolite on the outer skin of the door and a layer on the inner skin (closest to you) that completely covers the holes. I also threw in some stock deadening from the back wall that I can't use because of the amp rack. I had a bit of noise through the rear doors so hopefully that has changed.
Good work, this this is going to be DEAD.
I'm interested in hearing how much the spectrum helped out. I'm thinking about using it in my doors.
