Recently Browsing 0 members
Recent Topics
- 1 comment
- 16 views
- 33 comments
- 7,889 views
- 3 comments
- 102 views
- 402 comments
- 34,995 views
- 6 comments
- 1,768 views
- 20 comments
- 504 views
Similar Content
By Ryann627
Thanks in advance guys.
By 121gigawatts
I just bought a zv5 15 thinking it was dual 2 ohm and it’s dual 1 ohm. I have a few questions. First, can it be recone to dual 2? Because I read some motors are only configured to function on the original impedance. Idk. And if I can’t get it recone, can I run that amp at .5 ohm unclipped on that zv5 and not overpower it? Should I run it at 2 ohms? I hope it can be reconed to dual 2. In need of help. Thank u.
By Second Skin
Duster Joe's 1976 Plymouth Duster Trunk Build
Customer Joe M. Build Info:
1976 Plymouth Duster 2006 6.1L Hemi 1996 Borg Warner T56 (Viper) Trunk is 53 cu/ft space
Complete car was done with three boxes of Damplifier Pro (90 sqft total). Trunk specially was completed using 8-10 sheets of Damplifier Pro.
The trunk before any Damplifier Pro sound deadening.
Installing the Damplifier Pro butyl sheets.
Interior trunk walls only needed one full sheet of Damplifier Pro each to reduce sound to just a deep thump.
After the Second Skin Damplifier Pro was installed. The Damplifier Pro dropped the sound of the fuel pump to nearly no sound at all.
Here a picture showing the trunk sound deadening completed. It’s totally covering the floor, wheel wells and one full sheet of Damplifier Pro on each inner quarter panel. The rear trunk panel was completely done as well.
By Second Skin
The awesome guys at Colorado Car Audio just finished a sweet Dodge Ram 3500 Pro Master Van build with full sound and heat insulation along with a stereo upgrade and the work is very nice!!!
They applied Spectrum and Damplifier Pro CLD to all of the metal to kill vibration noise and help with heat transfer through the metal. They used Luxury Liner Pro MLV+CCF next to block out unwanted airborne noise and thermally insulate the walls. And they used Mega Zorbe Hydrophobic Melamine Foam to absorb sound and thermally insulate the roof of this huge van!!!
When the proper layers are applied to the correct locations, a huge difference in noise level reduction can be achieved. Setting the stage for a nice and clean platform for your stereo to perform in a much more enjoyable environment....especially with these tin can sprinter vans....treating them makes a HUGE difference in noise comfort levels.
Thank you guys for the awesome work and pictures. Thank you for insisting on high-quality Second Skin products for all of your builds. #TeamSecondSkin #SecondSkinUSA #SecondSkinAudio #SecondSkinForTheWin
Spectrum Liquid Sound Deadening
Luxury Liner Pro Mass Loaded Vinyl with Closed Cell Foam infused
Mega Zorbe Standard Hydrophbic Melamine Foam
Damplifier Pro
New Kenwood Touch Screen Head Unit
Upgraded Stereo System
Recent YouTube Posts
