Recently Browsing 0 members
Recent Topics
- 19 comments
- 366 views
- 3 comments
- 90 views
- 398 comments
- 33,880 views
- 4 comments
- 177 views
- 2 comments
- 749 views
- 5 comments
- 1,595 views
Similar Content
By jcarter1885
By Ryann627
Thanks in advance guys.
By 121gigawatts
I just bought a zv5 15 thinking it was dual 2 ohm and it’s dual 1 ohm. I have a few questions. First, can it be recone to dual 2? Because I read some motors are only configured to function on the original impedance. Idk. And if I can’t get it recone, can I run that amp at .5 ohm unclipped on that zv5 and not overpower it? Should I run it at 2 ohms? I hope it can be reconed to dual 2. In need of help. Thank u.
By Second Skin
Duster Joe's 1976 Plymouth Duster Trunk Build
Customer Joe M. Build Info:
1976 Plymouth Duster 2006 6.1L Hemi 1996 Borg Warner T56 (Viper) Trunk is 53 cu/ft space
Complete car was done with three boxes of Damplifier Pro (90 sqft total). Trunk specially was completed using 8-10 sheets of Damplifier Pro.
The trunk before any Damplifier Pro sound deadening.
Installing the Damplifier Pro butyl sheets.
Interior trunk walls only needed one full sheet of Damplifier Pro each to reduce sound to just a deep thump.
After the Second Skin Damplifier Pro was installed. The Damplifier Pro dropped the sound of the fuel pump to nearly no sound at all.
Here a picture showing the trunk sound deadening completed. It’s totally covering the floor, wheel wells and one full sheet of Damplifier Pro on each inner quarter panel. The rear trunk panel was completely done as well.
Recent YouTube Posts
